Old 12-26-2016, 08:25 PM   #1
The1960APE
The1960APE's Avatar
Anyone running 22" Transports ?
I found a set of 22" transports locally. Will I have issues running them on a 66 fleet side lowered 5-6" ? The 6" bs worries me a bit
1965 Olds 442 "Project Oldmobile"
1971 2wd GMC Jimmy..."The Orangutan"
1961 Apache "The Ape"
http://67-72chevytrucks.com/vboard/s...d.php?t=679735
The1960APE is offline   Reply With Quote
Old 12-26-2016, 09:31 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Anyone running 22" Transports ?
You'll probably have to run spacers to clear the huge center hub of the rearend.
The center hole of the transit wheels is too small.
MANY people have run these wheels on the 60-66 trucks but they're not a direct bolt on.
Keith
Convert to disc brakes.
Old 12-26-2016, 09:34 PM   #3
mehoff400
i am in the process of installing them on my 65 but its not lowered much yet
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 12-27-2016, 07:59 PM   #4
ebaby35
I was thinking if getting some but they are for 6 lug and I have 5 lug is there a way to make them work.
ebaby35 is offline   Reply With Quote
Old 12-30-2016, 02:01 PM   #5
protruck15
I have a set on my 66. It is running a stock rear diff so I took them into a wheel repair shop and had the center sections bored out to match the factory wheels. As for the front I have a Mcgaughys disc conversion so they were straight hubcentric bolt on. The offset makes it so I have to air up quite a bit to corner. I have never posted pics on the forum but if you are on instagram I'm @protruckdug to see fitment looks.
protruck15 is offline   Reply With Quote
