Old 12-27-2016, 01:05 AM   #1
kmswi
1976 gmc NO POWER AT EITHER SIDE OF HEATER FUSE WITH KEY ON
Key on, power ok at other fuses, where does the heater fuse get power from?
kmswi is offline   Reply With Quote
Old 12-27-2016, 06:56 PM   #2
CSHADES
CSHADES's Avatar
Re: 1976 gmc NO POWER AT EITHER SIDE OF HEATER FUSE WITH KEY ON
I would suggest you pull the fuse panel and look at the back side of it. It probably has a bad buss connector. Most of the things in the panel are powered by the same source. The old fuse panels get corroded over time and things quit working.
CSHADES is offline   Reply With Quote
