Old 12-27-2016, 10:23 AM   #1
eisanaa
1967 c10 brakes
My 1967 c10 has already been swapped over to disc brakes on the front, my question is how do you order new pads and rotors for it, it is stock height with 6 bolt wheels on it and everywhere I look on the internet it only shows swap kits there are no listings for replacement parts are there other years that used 6 bolt rotors that you can order or is it a buy another swap kit to get the pieces i need?
eisanaa is offline   Reply With Quote
Old 12-27-2016, 11:56 AM   #2
LongBox
Re: 1967 c10 brakes
Can't you find out what the original application for the parts in the swap kit was? Then a parts guy could sell you pads and rotors.
If that's not possible, I'd take the rotors and pads with me to a brake shop, and let them compare with parts they have to find what you need. Not a place like O'Reillys, but a real brake shop.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 12-27-2016, 12:09 PM   #3
ratty69
Re: 1967 c10 brakes
You need to determine how it was converted to discs. The most popular way is by using 73-87 spindles and calipers with aftermarket 6 lug rotors. Replacement rotors are available. There are no stock 6 lug rotors that fit 73-87 spindles.
Pic of aftermarket rotor: http://www.earlyclassic.com/fullImag...ion=03-6370-6L
The other way is by using bolt-on caliper brackets and bearing spacers to get stock 88-98 light duty 3/4 ton rotors and calipers onto the original drum spindles.
Can you post a pic of your setup?
ratty69 is offline   Reply With Quote
Old 12-27-2016, 12:11 PM   #4
weq92f
weq92f's Avatar
Re: 1967 c10 brakes
The pads should be easy enough just take one side used pads to a parts house and have them go find the GM pads that look just like the old ones.
You could get lucky and find some sort of casting or part number on one of the rotors too I suppose. The same method could be used, but I suspect with less chance of positive result.
If you know where this "kit" came from try to go that route first. I installed a Baer big brake kit once on an F-body. Years later, when I needed pads/rotors, a little research showed that the Baer kit was simply GM's C5 corvette rotors/calipers/pads. Cheap rotors and pads for replacement, but BAER wanted 3 times the price!!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 12-27-2016, 01:31 PM   #5
67c10rustbuket
67c10rustbuket's Avatar
Re: 1967 c10 brakes
6 lug rotors are aftermarket only. I believe ECE and CPP sell replacement rotors for the 6 lug disk conversion. Brake pads and everything else should be available at any auto parts store. They use 1971-198x depending on kit and rotor thickness.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 12-27-2016, 01:35 PM   #6
67c10rustbuket
Re: 1967 c10 brakes
Here is ECE 6 lug rotors
Dan <---(my name)
Old 12-28-2016, 07:57 AM   #7
eisanaa
Re: 1967 c10 brakes
The brakes were converted with a kit from summit racing (McGaughy's Front Disc Brake Kits 63157) along with spindles from summit aswell
Old 12-28-2016, 09:35 AM   #8
Mike C
Mike C's Avatar
Re: 1967 c10 brakes
Just call Summit and order replacement parts from them. There is no shopping for cheap price when you use aftermarket parts/kits. Just pay whatever it costs and move on down the road.
My dad bought the Jimmy in '77 and I got it from him in '87 and replaced the rotors around '98. Based on my experience it's nearly a lifetime product since I have over 350k miles on the truck now and just two sets. No way I could wear them out again!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-31-2016, 09:33 PM   #9
eisanaa
Re: 1967 c10 brakes
yes but the kit it comes with rotors pads calipers and flex hoses and i was looking to buy just rotors and pads, My 69 c10 is less of a headache as it has 5 bolt wheels
Old 01-01-2017, 10:51 AM   #10
dirtyjim
dirtyjim's Avatar
Re: 1967 c10 brakes
for rotors summit sells cpp 6 lugs https://www.summitracing.com/parts/clp-cp4r-6/overview/ I run them on my truck and this is the best price I've seen on them and free shipping. the pads will be the same from 71-mid 80's so just pick any year between them and you'll be good. hoses are probably el camino hoses
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 01-01-2017, 07:27 PM   #11
eisanaa
Re: 1967 c10 brakes
thank you that was what I wanted to know
