brakes......
Okay let me tell you what I'm experiencing.. Every once in a while when I come to a stop I feel like I have manual drum brakes(if you understand that).. I have a 71 blazer with power brakes. Everything is new for brake oriented except for booster and proportioning valve. The calipers are the wildwood replacement calipers... Like I said it seems when I come to a stop it seems to keep rolling even if I press on the pedal harder.. Scares me sometimes. Any Ideas what it might be? Thanks, Mike Happy Holidays!
![]() Join Date: Jan 2009
Re: brakes......
Check you vacuum line. Sound like you are loosing vacuum
Pulatoy |
#3 | |
Re: brakes......
I find it usually helps to find a clear spot and hit the brakes hard. My brakes usually feel much lighter and more responsive after this.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
Re: brakes......
That's the problem when mixing components. You say you're using Wilwood calipers that are a direct replacement, but did you check the piston surface area compared to your original pistons to make sure they were the same? That would be the first thing to do IMO. You may need to increase or decrease the bore of the master cylinder to suit those calipers.
Re: brakes......
Check you vacuum. Low manifold vacuum, leaky one way valve, leaky diaphragm, will all cause that.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
Re: brakes......
I had to add a vacuum reservoir when I changed my cam to have more boost. Then I went to Hydroboost. Much better now.
'72 K5, known as 'the Fox.' |
Re: brakes......
Re: brakes......
Dragging a trailer, it's the ONLY way to go
Re: brakes......
Re: brakes......
did yas make your own hydro or did ya buy the kit?
Re: brakes......
I bought whatever goes to a 1-ton and made it work.
Re: brakes......
Did you use your MC that was on the blazer or what you ordered?
#13 |
Re: brakes......
I was able to use what was on the Blazer. In fact, I didn't have to crack a line or bleed the brakes.
#14 |
Re: brakes......
Does it matter what type of booster ,Delco or bendix to use with a MC? Will a Delco mount to a bendix bracket?
#15 |
![]() Join Date: Dec 2013
Re: brakes......
I was experiencing a similar problem with braking and after reading various threads, I went to Advance auto.com and ordered a K3500 brake booster for $70. I reused the original MC shaft as instructed in the thread and it has made a huge difference.
You can find the exact same part at Rock Auto, but Advance seemed to have the best price. I used my Cadmium finish kit from Eastwood, for the look I prefer. I believe the booster also came black from the factory, but it is so prominent in the engine bay that I went with cadmium. |
#16 |
Re: brakes......
Most of these are pretty interchangeable. I would bet that you'll have no problem. I'm using an aftermarket booster (Tuff Stuff) on the factory bracket with an 03 MC, and everything fit together perfectly.
#17 |
Re: brakes......
buckkoo what year was the booster? It mounted to the power brake bracket?
#18 |
Re: brakes......
#19 |
Re: brakes......
Ochre did you already have the delco brake booster mount for yours? I have a bendix booster mount. I guess I need to find a delco one..
#20 |
Re: brakes......
What's the difference betwen the two?
#21 |
Re: brakes......
I used a 1972 K3500 Booster.
#22 |
Re: brakes......
apparently the mounting pattern. I believe the delco booster is a tad bit wider then the bendix..
#23 |
Re: brakes......
Not bolt pattern? Mine has 2 unused holes at the bottom and I can't remember if I had to drill any.
#24 |
Re: brakes......
can't say that I know what I have or what the difference is. It was the existing factory mount and the new 1 ton unit fit. The brace that goes under the booster and connects down lower on the firewall ends up being maybe an inch or so short, but playing around with the angle a little bit and a few washers here or there and it's pretty easy to get it to work.
#25 |
Re: brakes......
just loosen the bolts where the bracket mounts to the firewall to accommodate for minor difference in booster bolt spacing
