12-27-2016, 06:43 PM | #1 |
Orange and white wire
Hello,
Can someone tell me what this wire is for? I know it came off a plug off the steering column not sure where the wires go get connected to. Thanks, Ramiro |
12-27-2016, 06:48 PM | #2 |
Re: Orange and white wire
In normal applications the orange is BAT (hot all the time) and the white is the ground circuit switched side for interior lights. So your dome light would have these connections, for example.
What that particular connector is and why it'd be on your column I'm not sure. It looks damaged, like the orange connector has been pushed out of the housing, so check that before putting it back together.
12-27-2016, 07:55 PM | #3 |
All about them K’s
Looks like the Brake light switch connector. If I remember right orange should end up at the dome light connector and white should go to the big steering column plug.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
12-27-2016, 11:16 PM | #4 |
Oh ok. I need double check to make sure they are connected to the new wiring harness I just installed.
12-28-2016, 01:43 AM | #5 |
Post Whore
Brake light switch plug. The photos below sort of show it plugged in.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
12-28-2016, 02:09 AM | #6 |
01-08-2017, 05:20 PM | #7 |
Is there a certain way it gets plugged in into the brake switch? How can you tell which tab is for the orange or white from the brake switch. I'm about to hook it up.
Thanks, Ramiro |
01-08-2017, 05:35 PM | #8 |
Msgt USAF Ret
It's just a connector to power the white wire that runs to the steering column connector for the turn signal switch. It doesn't matter as long as they connect.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
01-08-2017, 05:54 PM | #9 |
