Old 12-27-2016, 10:04 PM   #1
wlt3355
H4 headlight conversion question
This may be covered somewhere else and is so, if someone could direct me that way.
I recently purchased a headlight conversion kit with all the new relays, but I mistakenly ordered a four liight kit and not the two light kit, can I convert this to a two light system?
And if so, what do I need to do? This is for 1972 C10
wlt3355 is offline   Reply With Quote
Old 12-27-2016, 11:16 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: H4 headlight conversion question
Sure, just use the 3-prong connectors which are intended for high-low beam lamps. Ignore the 2-prong, high beam only connectors..... they won't be used.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-28-2016, 08:52 AM   #3
wlt3355
Thank you, I had the feeling that it was simple solution
wt
Old 12-28-2016, 09:04 AM   #4
70cst
70cst's Avatar
Here are some threads that might add info ....
https://www.summitracing.com/parts/hla-002395801
http://67-72chevytrucks.com/vboard/s...d.php?t=664797
http://67-72chevytrucks.com/vboard/s...d.php?t=354375
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 12-28-2016, 06:53 PM   #5
wlt3355
Thanks guys for your input, finished this today, was a little confused for a few minutes as this kit came with the sockets for the lights, but also had a male three prong plug, after a few minutes of studying, realized this plugs into one of the old light sockets, made for a very simple hook-up, no splicing of wires, everything works great.
Walter
