12-28-2016, 09:18 AM | #1 |
Tie Rod Ends - Do I need to redo them?
I installed new tie rod ends in my truck last night and also did new drag link ends as well as they were worn. I got it all back together fine but when I was tightening the studs on the tie rods I didn't really think about how much torque they needed, I got the wrench and got them as tight as I could. When I got done I thought about the torque setting and went to check - internet says 45 lbs. I did a lot more than that.
Should I be concerned? Feel like I may have created a dangerous situation if I compromised the strength of the studs. Thoughts on this? Should I back them off and re-torque to 45 lbs or just toss them and buy new ones? |
12-28-2016, 11:33 PM | #2 | |
Re: Tie Rod Ends - Do I need to redo them?
I could find any torque specs either for chevy trucks
But my dodge ram 4x4 diesel service manual says 65-75 ft lbs for tie rod ends/drag link ends. Quote:
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
12-29-2016, 12:33 AM | #3 |
I found my old 71 service manual
K20- "Tie Rod Ball-joint Nut" - 45 ft lbs. Clamps - 35 ft lbs.
12-29-2016, 11:05 AM | #4 |
I guess my concern was the fear I damaged the stud or stressed it somehow. I ran the nut on with an impact on medium power and held the trigger down for a bit once it quit spinning. Then I threw a wrench on and snugged it up pretty tight.
I will say there was some play in the drag line but not much, the new parts really helped with steering feel. Amazing how much better it is. |
12-29-2016, 03:39 PM | #5 |
stick a cotter key in it and send it on it's way.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
