Old 12-28-2016, 12:48 PM   #1
cottonme173
cottonme173's Avatar
BBC 454 safe boring min.
Hello guys.
On my BBC Mark IV 454 I have just pulled the pistons and crank (and everything else )to get it Hot Tanked. I noticed the cylinders had a noticeable lip, enough to noticeably feel with a finger (.003 or so, so .006 minimum overall). I would like to get them bored to clean this up. Is there a safe bore .010 or around there that I can safely use the stock pistons? Or should I just be safe, go .030 and buy new pistons? I would love to just go stroker kit, but am thinking that would be pretty costly and I don't have a ton of cash to do this.
I don't have access to a bore mic, but I will be getting it tanked this week and the engine builder said he would check it for runout. I just wanted to be armed with info (first time doing this) and not pay for more than I need.
Thanks!!
cottonme173 is offline   Reply With Quote
Old 12-28-2016, 03:00 PM   #2
GRADYS Performance
GRADYS Performance's Avatar
Re: BBC 454 safe boring min.
Bore it to the next available oversize piston. Usually .030 over. If it is worn with that much lip you will not have a good ring seal if you just try to hone and use the original pistons.
GRADYS Performance is offline   Reply With Quote
Old 12-28-2016, 03:27 PM   #3
tucsonjwt
My Goodwrench rebuilt 454 has a brass ID plate on the side of the block that states it was bored .030 over. I don't know if that is good or bad, but Mr. Goodwrench liked it.
tucsonjwt is offline   Reply With Quote
Old 12-28-2016, 04:12 PM   #4
cottonme173
Ok, you confirmed what I was thinking. I will get her cleaned up and move forward with the bore!
