![]() Join Date: Oct 2016
new bed step part fustration...
![]() ![]() Join Date: Nov 2008
Re: new bed step part fustration...
Looks like, "Cut to fit, bend to suit, paint to match".
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
![]() Join Date: Aug 2012
or better yet..."Hmm...looks like i need a new hole..."
![]() Join Date: Sep 2011
At some point in its life your bed may have been changed from a 60-66 . You ordered the 55-59 bracket. Can you used the bracket shown attached to the bed?
![]() ![]() Join Date: Aug 2013
55 thru 59 brackets are different than 60 thru 66....as are the cross sills because of frame changes and widths.....wrong year bracket or bed?
The existing brackets you show are the style on my 62....my 56 has your new style....you probably have a later bed adapted?
X2^
As said, the brackets you ordered do fit the 56. drill another hole??
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
I guess I'm going to drill a couple holes, I just wanted to check first, this aftermarket parts stuff is frustrating to say the least! The holes in the bed steps are off and needing lots of work to make them straight and fit properly!
I'm wondering if those originals were from a different truck to begin with. seems as though from your pictures that your originals differ greatly from the new ones you've bought.
Post Whore
![]() ![]() Join Date: May 2015
Glad you got it figured out...in your first pic in post you can see that the new and old steps are different..the one where you have one on top of the other
#13 |
Glad you got it figured out. Do you have the rod that goes from the frame to the step to support it? I haven't seen it in your pics.
#14 |
I ordered a new set that I just received, I'm waiting for my garage to warm up as it was 32 degrees in the garage this morning and only 27 right now!
