rear trailing arm bushing
hey guys wondering why I cant find anything on poly bush for rear trailing arm. at least on what way they go together as in the two pieces. how one is tapered what side does that go thanks.
Re: rear trailing arm bushing
When you say trailing arm, the bushings can be found at most part vendors (ie LMC, Classicparts etc). They are pressed on until the flange is in contact with side of trailing arm.
Now when you say rear trailing arm bushing, you may referring to the tracking or sway bar behind the rear end. If so these bushings can be found at those and other locations mentioned also...
1970 C/10 350/T5 SWB stepper... 1979 Corvette 350/Auto T-top... 2010 Acura RL... 2015 2500HD Z-71 Silverado... |
Trac arm bushings (Left Picture)
https://www.summitracing.com/parts/e...del/c10-pickup Trailing (Control) arm bushings (right picture): https://www.summitracing.com/parts/e...del/c10-pickup
John San Diego, CA 1969 C-10 “ A person who never made a mistake, never tried anything new.” Albert Einstein |
oops, sorry misread your question! ignore my last post lol
I bought a set of Prothane ones from speedway and they came in the box put together and the taper was to the outside. I popped them apart and installed the same way. I wasn't sure but just did it that way. If I understand your question. You mean the big bushing at the front of the trailing arms ?
-Cody |
I mean on the ring that snaps on the outside of the bushing after you push the bushing in. And I put the rings to the outside towards frame, if that makes sense.
-Cody |
I didn't take any pics. I haven't noticed any problems with it that way. I put the bolts pointing out too. Nuts towards the frame
-Cody |
