Old 12-29-2016, 12:19 AM   #1
chrismoore701
chrismoore701's Avatar
Best radiator
I know this has been beaten to death but posts I find are old. I have a 1979 c10 with a 375 hp 350. I have a 3 core right now and it has a crack in each tank. I am going to look at having it repaired but it is over 25 years old. What is the best bang for the buck if I go to buy a new one?
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 12-29-2016, 08:20 AM   #2
homemade87
Re: Best radiator
Summit has some nice brass ones that will fit . If the one in my 82 has problems thats what I will be doing . Looks like oem and direct fit as well or very close .
I am not a fan of the alum/plastic end ones you get from the parts store . But it may give you your bang for the buck your looking for .
homemade87 is offline   Reply With Quote
Old 12-29-2016, 02:51 PM   #3
GM-power
GM-power's Avatar
Re: Best radiator
I got one from napa, 4 row if I remember correctly. I'm happy with it, 135 bucks and a lifetime warranty... it's aluminum with plastic tanks.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 12-29-2016, 02:53 PM   #4
Jaysonb
Jaysonb's Avatar
Re: Best radiator
I have used a couple of spectra premium radiators. The seem to fit good, and cool very well.
Jaysonb is offline   Reply With Quote
Old 12-29-2016, 06:11 PM   #5
tucsonjwt
Re: Best radiator
An old reference, but I was a brass/copper fan until they had repeated leaks here in the desert southwest. The cheap Spectra plastic/aluminum radiator I installed not long ago is better, IMHO. It is just a thicker 2 core and works fine with my 454.
As previously posted, I replaced the plastic/aluminum original radiator in my 2002 Cavalier last year after it had 146,000 miles of desert usage. It had no leaks, it was just clogged up and was causing overheating. I think 14 years of use is a good testament to plastic/aluminum.
You will likely find that getting a good repair on your radiator won't be cheap, and an aftermarket copper/brass will be about $450 or so. All aluminum is not a sure fix either. My friend has an Champion aluminum radiator and he has had fitting leaks and an undetermined coolant loss on that one.
Spend $100 on a plastic/aluminum and see how it works. Just don't torque down the radiator clamps too tight, since plastic is not very forgiving of this.
tucsonjwt is offline   Reply With Quote
Old 12-31-2016, 12:54 AM   #6
weider1717
Re: Best radiator
best is to record your original if you have it
weider1717 is offline   Reply With Quote
Old 12-31-2016, 07:34 PM   #7
chrismoore701
Re: Best radiator
Repair estimate is $50-$75 for the two holes could be more. Won't know until I drop it off for inspection.
Chris
Old 12-31-2016, 08:11 PM   #8
king-918
king-918's Avatar
Re: Best radiator
I would say get an all-aluminum double or triple pass radiator depending on what motor you running with
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
