70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Whats your truck plans for 2017
Because I live in the cold and snow belt and only use my truck from April till October tonight I made a list of what I wanted to do with/to it during the 2017 season. I made a list of 17 things for 2017 ( I actually have about 35 total things as the budget allows) that I want to do with the truck. So post up your plans for 2017 on what you want to do to/with your truck in the coming year and lets try to keep it to about your top 5 things. By the way you folks in the warm climes are very lucky being able to drive and enjoy your trucks year round. Happy New Year everyone.
My top things are: 1. Install the new Booster/Master I bought from Frank at Pickemup. 2. Do the brighter headlight relay upgrade. 3. Replace ( I have the part ) my broken drivers door vent window. 4. Install LED Bulbs in my Dash 5. Take my original radio and get it repaired so it works properly. 6. Lastly cause I only put 100 miles on it last year, drive ,drive, drive it !!!!
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: Whats your truck plans for 2017
This is a tough question. Not because I don't have some good ideas for my 69, but because I'm torn between leaving it all original, and making some simple changes to make it more like MY truck.
Changing out the factory step bumper for the chrome bumper would be top of the list, followed by finding a good set of 6 bolt truck rally wheels (15 by 8) for starters. I'd also like to put in the factory-style tach, and convert to power steering.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
![]() Join Date: Feb 2009
I retire on Friday, so by spring I should have the body off, and then I'll dive into to undercarriage. The cab is near ready to pull anyway. From there the restoration begins. The frame should be ready for a new body by year end.
That said, $#it has really hit the fan this week. This year hasn't ended on a good note. As they say, $#it happens.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
My plans are to build the clean 81 K10 I just bought yesterday plus all the other builds I have to pay for my build.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
![]() Join Date: Jan 2007
i would consider getting my big block installed by the end of 2017 a success.
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
My Top five things on a long list of to-do's for 2017;
1. Clean, Media blast and POR15 every single frame/chassis part there is. 2. Refurbish/rebuild and assemble rear suspension, diff. and brakes (sit it on it's rear wheels again) 3. Refurbish/rebuild and assemble front suspension, steering, brakes (sit it on it's front wheels again) 4. Rebuild transmission (ready for install) 5. Start collecting engine parts for it's rebuild (goal to run again Spring 2018 - at latest) |
#7 | |
17 for '17, huh.
1. Get it home 2. Get it running 3. Repair rockers 4. New carpet 5. New tires 6. Fix door handles 7. New fuel pump 8. Recolor the interior panels 9. Add a tilt column 10. New steering wheel 11. AC repair 12. New brakes 13. New points, plugs, wires, 14. New shocks and coils 15. Bed rust repair 16. Fresh paint on bumper 17. Full detail on exterior (saving the grease pencil marks under the hood) So, basically a cheap restore with as many original parts kept as possible.
"Don't get it right. Get it running." -David Freiburger 2014 GMC Terrain I4 (wife's new ride) 2005 Dodge Magnum 3.5 (wife's old ride) 2003 GMC Sierra 5.3 Extended Cab 1972 Chevy Cheyenne 350 |
1.fix the rust
2.give her a new set of boots 3.a complete tune up 4.add power brake booster and disc brakes to front 5.continue to drive the wheels off and enjoy every minute😎
1970 chevy k10 305/4 speed |
Collector of Projects
1. Get it back from the body guy
2. Build a console 3. Build custom bumpers 4. Finish the stereo install |
![]() Join Date: May 2007
1.New chassis
2. Cab Repair 3. Sheet metal repair/ replacement 4. LS3 525 engine install If I get all of this done it will be a good year. ![]() |
1. Lower the rear 2"
2. Install a seat out of a 88-94 truck 3. Rebuild the doors: latches, regulators, seals 4. Put together the 455 Oldsmobile and rebuild the 4L80E 5. Install #4 with the Holley Dominator EFI 6. Fab and install rear mount gas tank I've got all the pieces and parts I need except for the seat. The truck is just waiting on me!! |
#13 |
![]() Join Date: Jun 2009
Finish and drive it !!! 10 years has been long enough of a wait
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
#14 |
For me just a few things:
1. Replace trailing arm bushings 2. New inner and outer tie rods 3. Lower ball joints 4. Replace rear shocks
1970 C/10 350/T5 SWB stepper... 1979 Corvette 350/Auto T-top... 2010 Acura RL... 2015 2500HD Z-71 Silverado... |
#15 |
![]() Join Date: Dec 2012
I did a ton of things last year, so far only three new gauges and hoping to put in a Lokar floor shifter
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#16 |
![]() Join Date: Feb 2001
To get my truck finished ... its recovering from Tornado damage at the Egyptian ...
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#17 |
'72 K2500:
1- Repair rusted rockers and cab corner 2- Powder coat new wheels 3- Set of tires 4- Replace printed circuit/repair cause of original frying 5- Tunes Most likely get 2, 3, & 4 done. The other two would be nice. ----------------------------------------------------------------------------------------------- '67 C1500: 1- Glass in cab 2- Front clip on 3- Install engine & trans <<< Really all 5 are one, get running, and the others are what it takes to get there 4- Make exhaust/driveshaft 5- Wired up and running If I get the cab closed in and front clip on I'll be happy. The engine/trans install is no biggie, just want 1 and 2 done first. Gotta buy windshield and window seals for #1 and the rest is just do it. 4 and 5 will take money, so all depends on that sitiation
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 12-29-2016 at 09:53 AM. |
#18 |
What used to be a fantasy list is now becoming a reality list.
1. Redo the bed wood. Cost $200 (cutting and routing the yellow pine my self) 2. Install a blazer tank and side filler door. Est $300. ( kit + welding mod on frame) 3. Remove the tank from the cab and fab a panel to hold speakers, amps, and subwoofer. $100. (Need to buy the Fiberglass sheet an resin, rest of materials on hand) 4. Front disc brake conversion $900 (this one is a stretch for this year. May have to wait till '18) |
#19 |
Hopefully turn it into a dump bed if I can find the time.. Oh, also power steering. my spaghetti arms are tired of fighting that wheel. LOL...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. Last edited by hamjet; 12-29-2016 at 09:08 PM. |
#20 |
Considering a Weiand 142 supercharger
1970 C10 Short Stepper with 71/72 front clip. |
#21 | |
![]() Join Date: Jul 2015
Are the windshields different between the 67-72 years?? I might have what you need, somewhat local to you too. As far as a list for me hmm Get the cab off prep and get the frame apart take apart and then build the bed I have with mostly stock or NOS parts Fix or find a cab
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
#22 |
I never seem to get anything done, so anything I post would just be a lie
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#23 |
We're having our first kid in a few weeks, so once my truck arrives, if I'm able to drive it to work once a week without anything breaking and maybe do one or two longish drives in early summer, that will be a pretty big win for me.
#24 |
#25 |
![]() Join Date: Sep 2016
Drop spindles, flip kit, I say 18 but will most likely buy 20 wheels/tires,rebuild heater controll assembly ,cowl hood, I just bought the truck so this is a good start.
Posted via Mobile Device |
