Old 12-30-2016, 10:46 AM   #1
reed62
reed62's Avatar
15x8 Wheel and tire combination
Hey all,
I have the "rally" style wheels that Chevy used on the 1/2 ton pickups from 73-87. They are a 15x8 size wheel. I am trying to find a good street tire for them. I like the BF Goodrich T/A radials. The old tires that were on these rims were a 235 60 R 15 Hoosier....if memory serves me correct. I had the old tires removed so I could media blast and powder coat the rims. I lost the piece of paper I wrote the tire size on so now I am trying to see what tire looks good on that 8 inch rim. The local tire store said the best tire would be a Pathfinder tire but it is 30 x 9.5. I have 2" drop spindles up front and 3" drop coils in the rear. The 30 inch tire lifts the truck back up to where it was originally when it left the factory. I want to enhance the lowered suspension with a complementary tire. What they mounted for me are more like off-road tires with a really aggressive tread.
Would like to see some examples of some nice weekend street cruising combos.
reed62 is offline   Reply With Quote
Old 12-30-2016, 10:56 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 15x8 Wheel and tire combination
Here is 22 pages of pictures on tires and wheel combos that I found in the FAQ section:
http://67-72chevytrucks.com/vboard/s...d.php?t=379110
Old 12-30-2016, 11:43 AM   #3
65chevysub
65chevysub's Avatar
I'm running the 5 lug version of those wheels on my 65 Suburban. They came off of an 86 Suburban, and I am running 235/75R15 generic tires from Walmart on mine. They ride nice, and seem to hold up ok. I'm trying to get my chrome smoothies back that I traded for the rally's as I like the chrome better.
65chevysub is offline   Reply With Quote
Old 12-30-2016, 12:03 PM   #4
reed62
reed62's Avatar
That's interesting....I originally had them mount up a 235/75 15 and it was really ballooned out on the sidewall. I didn't like the look of it. I've seen some pics on here with 255 60 15 and they look really good with a 5/4 dropped suspension
Old 12-30-2016, 12:47 PM   #5
15x8
275/60 rear 6" drop
245/60 front 4.5" drop
Old 12-30-2016, 01:15 PM   #6
reed62
reed62's Avatar
15x8
275/60 rear 6" drop
That looks more like what I am aiming for. I ordered 245/60 for all four corners. I have the 2.5 drop in front and 3 inch at the rear.
Thanks for all the inputs everyone!
Old 12-30-2016, 07:01 PM   #7
Mackie
Mackie's Avatar
My truck has 2.5" drop spindles and torched coil (by PO) rear drop with 8x15 ralleys. The truck came with 225/60's I thought were too passenger car looking. I went with BFG Long Trail T/A Tour 235/70-15. It's a daily D so I run the same size front and rear and rotate. I have no rubbing issues and the look suits me, being radial with fairly square shoulders and not very aggressive tread. Not too good in the snow but I moved south last year.
Don't have a good pic but I can get 1 over the weekend if you want.
`63 C-10 Shortwide
Roller 305 LT1 cam, Eddy 500
T5
Mackie is offline   Reply With Quote
Old 12-30-2016, 08:48 PM   #8
duallyjams
duallyjams's Avatar
235-70 r15
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-30-2016, 10:39 PM   #9
Mackie
Mackie's Avatar
Yeah, like his ^
`63 C-10 Shortwide
T5
Old 12-31-2016, 01:05 AM   #10
Captainfab
60-66 Nut
On my Suburban I have 275/60R15's on the 15 x 8 Rally's on all 4 corners.
Old 12-31-2016, 01:33 AM   #11
Slow Build
Slow Build's Avatar
I would suggest you try to get a tire that's close to 28" tall. Both 235/70/15's and 275/60/15's are 28" tall. Depending on which drop spindles you may be able to run 275's all the way around. Most drop spindles move the wheels out 3/4" per side. I'm running 275's all around but I have only a spring drop now and when I install my new front end I'll use CPP Modular drop spindles so my wheel/tire combo should still work.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 12-31-2016, 11:23 AM   #12
65chevysub
65chevysub's Avatar
Several years ago I had 255/70 15 Firehawk SS tires on my truck, but they were too wide, and now I have bare metal on the inside of my wheelwells. I am going to get back to as close to the original size as I can(225/7515).
Old 01-01-2017, 11:26 PM   #13
reed62
reed62's Avatar
I went with 245 60 15 all the way around. Sorry the pics came out sideways. Not sure how to correct that...
Old 01-02-2017, 10:30 AM   #14
ImpalaJim
ImpalaJim's Avatar
265 60 15
ImpalaJim is offline   Reply With Quote
Old 01-02-2017, 01:18 PM   #15
Chevy Fleetside
Chevy Fleetside's Avatar
255/60 up front 275/60 rear. 3/4 drop. I want raise the rear up 1" for more rake.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
