Trans Pan on Turbo 350
I'm trying to remove the Trans pan from my Turbo 350 on my 2wd 72 C10. I can't seem to remove the pan as it gets stuck between the cross member and internal parts inside the trans. Is there any trick into getting the pan out?
#2 | |
The Older Generation
Re: Trans Pan on Turbo 350
I don't remember running into that problem. I would just loosen or remove the trans mount bolts and jack the back of the trans up enough to get it out. Try loosening them up first to keep everything lined up. Keep backing them out and jacking the trans up a little bit at a time. Post back and let us know if that works.... LockDoc
Who Changed This?
![]() Join Date: Jan 2013
What LockDoc says will work. I've seen this in cars, but not in trucks. Keep an eye out for any shims that may be between the trans mount and the crossmember.
#4 | |
![]() Join Date: Nov 2014
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
Thanks, That worked perfectly. Just jacked up the trans a bit and it came right off. The reason I was taking the pan off was I have slipping issues in Drive. If I put the trans in "D" and tried to go it would act like the trans was slipping. It would get going after a while and a good amount of slipping. It would start out fine if I started in "2" and then just shifted into "D" manually after I was at 40 MPH or so.
I dropped the pan on found this. I bought the trans from a shop that rebuilds them and it has about 2,800 miles on it. Warranty is long gone. Shroud there be this much built up? All of it can be picked up by a magnet. |
I'm not a trans expert but that is way too much crud for 2800 miles. What did the screen in the pickup look like? I'll bet the clutches are burnt.
Here is the filter.
