Old 12-31-2016, 12:19 AM   #1
ssupraman63
63 c10, LS swap, motor mount question..HELP
I have a 63 c10, I have switched the complete front suspension ,brakes, engine cradle,from a mid 80s c10, the parts you see in the pics, bolt from the 63 frame down to the mid 80s cradle, then the clam shell mounts to them, and so on, my problem here is that these pieces that are off of the newer c10 are too long now, what is everyone with this set up doing? Any help would be appreciated.
ssupraman63 is offline   Reply With Quote
Old 12-31-2016, 01:18 AM   #2
Captainfab
60-66 Nut
Re: 63 c10, LS swap, motor mount question..HELP
You need the engine mount brackets from a C20 or C30. They are shorter and fit the early frames better. Even then some guys prefer to add about a 1/4" spacer on top of the frame. You will also likely need to trim the top flange of the frame back a little.
Old 01-01-2017, 03:46 PM   #3
ssupraman63
83 views and 1 reply? thanks capt fab
Old 01-01-2017, 07:25 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I used the POL tubular mounts so I'm of little help for you....
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-01-2017, 08:09 PM   #5
Mathew21
Mathew21's Avatar
I swapped a 87 crossmember in my 66'. I used the my original factory V8 perches attached to dirty dingo sliders when I did my 5.3 swap.
Link with pictures for reference of original perches. http://www.persh.org/pickup/perches.htm
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 01-01-2017, 08:10 PM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
Well around here when CaptFab speaks your question is pretty much answered.
Old 01-04-2017, 01:08 PM   #7
ssupraman63
I am sure Mr. fab is very knowing on alot of things including this , but of coarse I am looking for choices , and since these others have shared their ideas I now have that.I am on a budget and hope to use what I have or go the cheapest route, I'm gonna take a look at my original perches and go from there. thanks everyone
Old 01-04-2017, 01:25 PM   #8
ssupraman63
so it looks like I have the matching factory perches, for the v8 and 230/350 , you are saying those will connect straight to the dingo mounts? nothing in between?
Old 01-04-2017, 03:06 PM   #9
jtrichard
dingo mounts???????
As for the clam brackets as Capt. said the c20 brackets fit better ...also there is a post some where here but i have yet to find it again where the guy cut / shortened (at the top) and welded them back together to fit and others have used spacers on top of the frame and under the bracket
jtrichard is offline   Reply With Quote
Old 01-04-2017, 05:33 PM   #10
ssupraman63
I actually thought about cutting the 73-87 perches I have , but no one had mentioned that yet except you... thats why I posted this to see what others are doing, keep em coming guys
I meant , dirty dingo sliders above.
Old 01-04-2017, 08:38 PM   #11
Mathew21
Mathew21's Avatar
This is what I used. http://www.dirtydingo.com/shop/index.php?cPath=359_360
I have a pair of C20 mounts like captain is describing somewhere around here. That's what I was going to use but went with the stock perches and dirty dingo mounts instead. If you're interested in going that route I will see if I can find them.
Old 01-04-2017, 08:47 PM   #12
Mathew21
Mathew21's Avatar
Here's a link where some others have used the 73-87 perches. http://67-72chevytrucks.com/vboard/s...d.php?t=662705
Old 01-05-2017, 01:54 AM   #13
ssupraman63
good stuff Matthew, did everything go smooth that route or may I run into problems with exhaust or ac compressor hitting the frame
on ls swap
Old 01-05-2017, 02:25 PM   #14
Mathew21
Mathew21's Avatar
Everything went real good on my swap. I do not have A/C. I thought I remember reading you have to get an A/C compressor relocating bracket to run it our trucks. I used Trailblazer SS exhaust manifold in my swap.
