12-31-2016, 10:24 PM | #1 |
Distance between axle perches?
I am converting a 71 GMC from leaf springs to the Ridetech trailing arm coil over set up. I need to know the stock distance between the axle perches.
Any help would be appreciated. |
01-01-2017, 11:14 AM | #2 |
Re: Distance between axle perches?
Being that the perches a set on a angle and also there are many obstructions to get a straight line from perch to perch , it would make it a good gestamate at best for the distance mesured between both perches .......... My gustament tells me from rear Ubolt hole center to hole center would be 41'' 1/2''
01-01-2017, 12:01 PM | #3 |
Thank you for taking the time to measure.That helps me out.
01-24-2017, 08:21 PM | #4 |
You may have already set up your rear end, but here is an old thread where I took some measurements.
http://67-72chevytrucks.com/vboard/s...d.php?t=217421
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
01-24-2017, 10:12 PM | #5 |
Thanks for the link. I haven't welded them on yet so I can still tweak them. Trying to figure out where to set my pinion angle then I weld them up.
