Wiring problem
Hi guys,
First, a full happy new year for all of you and yours. Since I got my C20, I throw few looks in my engine compartment, and I found an unplugged wire on the drivers side near the firewall. Here is a picture of it, if any of you know where it is plugged and the purpose of this cable, it looks like a grounding cable. Many thanks, |
Re: Wiring problem
Take a look at the brake switch near the master cylinder,just a guess on my part.
Re: Wiring problem
Thanks I'll have a look
Re: Wiring problem
looks like a ground strap that attaches to engine.
Custom Sport W/T
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Re: Wiring problem
1968aj is right on it is a ground strap and needs to be connected to the engine. May have been originally under a valve cover bolt. You can never have too many ground straps so find a spot and connect it up. Happy New Year.
Re: Wiring problem
Thanks a lot, I will put hands in grease asap ;-)
![]() Join Date: Mar 2003
Re: Wiring problem
That ground strap commonly went under the rear valve cover bolt
