Old 01-01-2017, 11:02 AM   #1
dave`12
dave`12's Avatar
Advice lowering rear only
67 c10 fleetside. It has the "helper" leaf (factory option) in back. But it's coil, not leaf.
Here is a pic of how the truck sits. Those 24" wheels are going, I'm gonna put some 17 inch ones as soon as I can find something.
Anyway, the rear sits too high. I want to get it the same height as the front without spending a ton of money.
I remember cutting the coils on a 69 Firebird that I had, but ended up lower than I would have liked, plus I hear people saying that cutting the coils can be dangerous (mine never gave me trouble).
Any advice on getting it the right height? I think I will most likely get the new rims before too long, should I wait?
thanx
dave`12 is offline   Reply With Quote
Old 01-01-2017, 08:09 PM   #2
PGSigns
PGSigns's Avatar
Re: Advice lowering rear only
I would wait till you get the new wheels on it. Then look at about how much lower you want the entire trick. You may find with the new wheels and tires you may want to bring it down on both ends. On the rear you cant cut them. They have a special wind on both ends that the retainer plate goes on to hold the spring under the truck. Easy way to go lower is just to swap the springs.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-02-2017, 10:15 AM   #3
dave`12
dave`12's Avatar
thanx for the advice on not cutting, PGSigns. I was thinking new springs would probably be the advice.
And I agree, the new wheels should probably be on first...
Old 01-02-2017, 02:40 PM   #4
dave`12
dave`12's Avatar
I would like to know how low I can go without a c notch if anyone can advise.
thx
Old 01-02-2017, 07:03 PM   #5
PGSigns
PGSigns's Avatar
Easily go 4 1/2 in the front with 2 1/2 drop spindles and 2 inch springs and 5" springs in the back. You will need to cut the bump stops down but it leaves you room to use the truck and not bottom out all the time.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-23-2017, 12:15 PM   #6
dave`12
dave`12's Avatar
Thanx PG
Old 02-11-2017, 04:41 PM   #7
dave`12
dave`12's Avatar
Lowered it 2 inches yesterday. 1 hour, 68 bucks for the lowering kit. Much better.
Old 02-11-2017, 08:39 PM   #8
bbbc10
Diggin The SquareLife
why does the rear wheel look not centered?
bbbc10 is offline   Reply With Quote
Old 02-12-2017, 08:21 AM   #9
dave`12
dave`12's Avatar
Always been that way. I have no idea. Everything looks good underneath and it handles as well as can be expected.
