Old 10-13-2003, 03:45 PM   #1
Castiron9
72 LONGHORN OWNER
Castiron9's Avatar
Questions..Questions
Noticed that the battery on Longhorn is spewing water out of top cell..Covers??????When I run truck,,,,,,,,, battery meter goes way past "c" and almost off to the far right?????????New alternator.old battery...I did notice alternator making squeaking noise??/Bad alternator?I also just noticed black wire attached to side of body by battery not attached to anything..Is this some sort of ground and does it attach to battery also?Any help would be appreciated
72-SUPER CHEYENNE/20 LONGHORN
70-C/30 DUALLY
Castiron9 is offline   Reply With Quote
Old 10-13-2003, 04:20 PM   #2
cheatham
I need a brake!
cheatham's Avatar
A new voltage regulator corrected the same problem for me- figured this out after frying the new altenator.
JP
MEMBER OF THE DISCS UP FRONT CLUB
1971 Chevy C10
cheatham is offline   Reply With Quote
Old 10-13-2003, 04:35 PM   #3
Gordo
Smile
Attach a volt-meter (if you don't have one, buy a cheap digital one) to the batt posts, with the engine running, warmed up, at cruising speed/rpm you shouldn't have over 14.2 V, if so replace voltage regulator. If it's 13.8V to 14.2V, have your batt tested. If it's under 13.8V have your alt and batt tested.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 10-13-2003, 07:43 PM   #4
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
If you don't have a wire running from the frame to the engine, you may have problems with the charging system. It needs to know where ground is.
My buddy bought an 80-something rustang from his sister, who said it always cooked batteries. We hooked the (-) to the frame, and never had any more problems with batteries. The rest of the car, on the other hand, lived up to it's name...
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 10-13-2003, 09:54 PM   #5
Gordo
Smile
71GMC_3/4T has a good point! With that voltmeter you can test your grounds. Set the scale for 20VDC and attach one lead to the neg post of the bat, then start vehicle and turn everything on (headlights, heater etc) using the other lead from the meter touch other grounds such as the engine block, radiator support, frame, cab etc. You should not get any readings over .5 volts if all your grounds are good. If you get a high reading (as an example) when touching the radiator suport you need to clean or replace or add a ground strap from bat to rad support.
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1951 Wife
Old 10-13-2003, 11:09 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That is good advice, but you should probably count on a new regulater and probably a new battery now too.
Old 10-13-2003, 11:10 PM   #7
Longhorn Man
Oh, clean up everything that your battery puked on too.
A solution of baking powder and water will neutralize the acid, and then rinse it all real good.
Old 10-22-2003, 12:45 PM   #8
Castiron9
72 LONGHORN OWNER
Castiron9's Avatar
Thanks for all the info.Replaced voltage regulator and grounded engine to frame as I had forgot that ground after rebuilt and seems do be doing much better...Battery meter now running right in the middle and not way off to the right .......Thanks guys............
70-C/30 DUALLY
