01-01-2017, 06:37 PM | #1 |
Any body running a fuel injected vortec in a apache
Is any body running a fuel injected motor in there 55-59 Apache just looking for ideas on where to mount the computer. Also just looking for other ideas thanks
01-01-2017, 08:10 PM | #2 |
Re: Any body running a fuel injected vortec in a apache
Not on a an Apache but on a '47 AD. The computer and associated electronics, relays, fuse box etc. take up a lot of real estate. In my case I built a panel and mounted the whole package behind the seat. On my '46 I mounted the CPU and fuse box under the dash and on the right side of the glove box. It's very packed and hard to access if needed on that one. The '46 is a '93 TBI unit, the '47 is a '03 Vortec injection system.
Rob
My '47 C.O.E build |
01-01-2017, 08:21 PM | #3 |
That's a great idea thanks
01-01-2017, 08:25 PM | #4 |
Post Whore
I 100% agree with fasttoys..I put my first one behind the dash and glovebox....never again..from then forward the only place for me is under or behind the seat..
01-01-2017, 08:36 PM | #5 |
This is an old picture of where I have the computer mounted but I need to find a better spot
01-02-2017, 09:18 AM | #6 |
I have an older computer which I mounted under the LH side of the dash above the park brake handle. It's not water resistant like the Vortec boxes and it's slightly smaller. I using a later, water resistant computer I'd probably paint it a contrasting color from the engine compartment and mount it on the LH inner fender behind the headlight.
01-02-2017, 10:10 AM | #7 |
Thats a great idea, I put mine under the dash. Talk about 20lbs of garbage in a 5lb bag.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
01-04-2017, 12:42 AM | #8 |
TPI in my '57:
01-08-2017, 12:43 PM | #9 |
Nice im running a vortec but added a ramjet
1959 apache 1948 chevy coupe http://67-72chevytrucks.com/vboard/s...d.php?t=562949 1964 gmc burban build for pops http://67-72chevytrucks.com/vboard/s...d.php?t=724632 |
01-08-2017, 01:14 PM | #10 |
Running? Well, not yet.
"...in an Apache..." Uh no, mine's a '55.2 not an "Apache" (58-59) but I assume you mean any Task Force year truck: The computer will likely be under the seat or possibly behind it like Roger's.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
