Motor mounts will not line up
So I tried installing the engine this afternoon and the motor mounts will not line up. I have everything completely loose. The driver side went in perfect but now the passenger side is about 2" off. Are the frame stands or mounts side specific? I don't know what I am doing wrong. Can someone please help me figure this out??
Re: Motor mounts will not line up
I have pictures but can't figure out how to post them from my phone.
Custom Sport W/T
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
2" off is a definite clue that something about the stands is amiss. What engine are we installing? What was changed from the previous engine being bolted up? A picture of each side will be a help.
![]() Join Date: May 2016
I think there is a left and a right. And when I think I put mine on. I had to leave them loose. Was just the nuts started. And I think the bolts were a little on the long side. Hope this helps.
It's the same block that came out of it. The only thing that is different are the motor mounts. Could they possibly be the wrong mounts?
Are the frame stands side specific? It's been so long since I took it apart I don't remember. The motor mounts look exactly the same...
Edit- your mounts are totally different from the ones on my truck.
You are using the clamshell mounts on the motor. You need the earlier style. 67 to 72. Small block V-8 style. There is a single stud in the center.
I'm completely confused now. The mounts on the motor are the same ones I took off when I pulled the engine. Could someone please post a picture of what I am supposed to have. My pick-up is a 1970 Chevy and it's a 350 block. Thanks for the help so far.
I have no idea if the block is original to the pick-up. Could it be a later style block and I bought the wrong mounts?
Someone must've adapted the clamshell mounts to the frame stand mounts. Is there a center hole in the pedestal frame mounts? If there is. You can just buy the rubber mounts bolt on the block. They have one stud on them. I will go take a picture.
Hope this helps.
#13 |
There isn't a hole in the center. Just the 3 that line up with the block. Could mine be a later year model?
#14 |
So what part is new, the mounts or the stands? Is your motor a small block?
Brad handshoe |
#15 |
What year model trucks used the clam shell style motor mounts?
#16 |
Mine has three on the block also. I'm talking about the one that is mounted to the frame. But your Frame mounts look different than mine. Someone might've change them over. Can you get a better picture of the Frame mounts. If you put your finger underneath the frame mounts. And feel for a single hole. But if everything was already mounted there once. You would think it would go back together. Maybe you have to flip one of the mounts around.
#17 |
look like 73 and up style mounts might have to take the one bolt back out and jockey the motor around a little but they should go ive seen them off more than that and go just a pain
#18 |
The mounts are new. It's a small block.
#19 |
There isn't a hole in the center of the frame mount. The only holes are the ones for the motor mount.
#20 |
Yes mines is a small block too. Were these mounts already installed once? Or is this a new build? I guess what I am saying is was this motor and the mounts already installed when you got the truck?
#21 |
These are the same mounts that are on it when I bought it. I pulled the engine and it was rebuilt and everything is back just like it was. Here are some more pictures.
#22 |
Post Whore
![]() Join Date: Feb 2016
Are you hanging the motor from a hoist or raising it with a jack? I have found hanging it to be easier most of the time. You may have to loosen ALL the bolts to the frame and the block as loose as possible and still have them stay connected. Then put your fore and aft bolts in and then set the engine down. Pointed line up bars and a flat pry will help along with a good supply of curse words.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#23 |
Sounds like good advice. H0455. X2.
#24 | |
![]() Join Date: Dec 2013
^^ There's nothing wrong with the mounts they work fine you just have to MUSCLE them a bit to get them aligned loosening the bolts will help . ![]() |
#25 |
IT'S IN!! So I finally decided to put the drivers side bolt back in and took the frame stand off of the frame and attached it to the motor mount. Then I lowered it back down on the frame. It was still off a little but waaaayy closer than what it was. I was able to get the bolts back in the top of the frame stand and used a 2x4 and a hammer and was able to get the bottom hole lined up. That with a few choice words got it done!! Thanks for everyone's time and help.
