Cab Installation
Just got my 1965 C10 back from painthe and need to install the cab back on the frame. There is plenty of play with oversized holes in cab mount brackets. Does anyone have any tips on how to make sure the cab in sitting square on the frame? I sure I need to measure from some point on the cab to the frame on both sides but I am not sure what the best reference points would be.
#2 | |
Re: Cab Installation
Every cab I have ever installed needed to move around some when the front cap was assembled to it. You may consider leaving the cab bolts just finger tight / snug until you get around to building the front cap up.
#4 | |
![]() ![]() ron |
Andyh1956 hit the nail on the head. Install the front clip and adjust cab as needed. It will surprise you how much a little movement on the cab can effect inner and outter fender alignment. It will also help to square the cab to the frame. I honestly don't know how many times I've bolted and unbolted the front clip and doors as I've replaced metal on the cab. That said there may also be some adjustment required when box is mounted so the gap between the cab and box is the same. Take your time, measure and install and uninstall as required. If something doesn't look or fit right try to think about all the parts involved not just the part your looking at. Good luck. |
