Old 01-02-2017, 07:49 AM   #1
hogfarm
58 Fleetside bed
While working on my 58 Fleetside,the fender wells had been flaired,(not a good job)I have one side back to original but the other side is in bad shape.Does anyone sell patch panels for the Fleetside?
hogfarm is offline   Reply With Quote
Old 01-02-2017, 10:53 AM   #2
N123DY
If you find someone, please let me know! I need some lower rear quarters.
N123DY is offline   Reply With Quote
Old 01-02-2017, 03:41 PM   #3
hogfarm
Re: 58 Fleetside bed
I did stumble across a post here about using 1960 wheel arch patch panels,are they the same or would I need to replace both sides
Old 01-03-2017, 09:05 AM   #4
hogfarm
OK i'm getting a better understanding of the differance between a 60 and a 58,I think the 60 is the same arch as the 58
Old 01-05-2017, 08:40 PM   #5
scuzz
I have also been told by "professionals" that the bottom half of 60 up is same as 58-59 Fleetside.
I replaced right rear corner on my 59 Fleetside by just rolling flat piece of cold roll to shape and tacking in.
I reverse rolled an inch or so into the spear section because I think the seam would be easier to hide in the roll as apposed to the flat surface below it.
Truck painted and you can't tell a thing.
scuzz is offline   Reply With Quote
Old 01-06-2017, 08:02 AM   #6
hogfarm
nice job scuzz
I think I will have my body guy stop by tomorrow,I can cut wheel out and replace it with a 60 one ,but there is the curve just above the opening.It will take me a day or two to make the tooling for a 5min job.
Old 01-06-2017, 11:37 AM   #7
1957 Chief
While the 60-66 fleet side beds look the same from the "bullet" down, the major difference is the wheel well opening. The 58-59 beds have about a 3/4 inch flat lip, whereas the 60-66 beds come to a point.
What I have been doing is taking a patch panel from the front wheel well opening of 55-59 fenders to fix that area.
Bubba
1957 Chief is offline   Reply With Quote
Old 01-06-2017, 02:35 PM   #8
Russell Ashley
Russell Ashley's Avatar
Scuzz, the bed job looks great. I noticed that you are in Tunnel Hill. My nephew has a blasting business called Flintstone MediaBlasting near Lafayette and does a lot of car parts. His name is Mitchel Kingsley, Just wondering if you know him.
Russell Ashley is offline   Reply With Quote
Old 03-15-2017, 06:33 AM   #9
hogfarm
Did anyone figure out what I can do?
Old 03-15-2017, 10:28 AM   #10
dsraven
is the opening close to a front fender opening? maybe a wheel opening patch panel from a front fender could be used? got any donor front fenders?
my fleetside box went to a good home. sorry, can't compare, but it looks kinda close to a front fender opening, kinda sorta in a way.
Old 03-15-2017, 05:21 PM   #11
hogfarm
I gave away my old rusted front fenders,could use them now
Old 04-05-2017, 07:22 PM   #12
scuzz
I know him. Flintstone Blasting of something like that.
He blasted my hood and several small pieces.
