01-02-2017, 09:10 AM | #1 |
2/4 cheap drop ? Post pics
Just got a 68 lwb this Saturday , it has drums and i don't want to change them yet and with buying the truck for 3500 i need to save up money for a while for a 4/6 drop , wheels and tires , and discs up front . Do I need to put different shocks with a 2/4 and a new track bar or will I be ok ? I was also thinking of cutting one coil out front and using TJ springs out back that I have laying in the shed .
01-02-2017, 09:28 AM | #2 |
Re: 2/4 cheap drop ? Post pics
You will be fine with everything you have. tearing it apart will be fun.
01-02-2017, 11:33 AM | #3 |
Yep that's what I did 1 coil up front and the TJ springs out back , I did notice it was a bit springy/boucny in the back. I made shock relocaters to make them stand more upright ,made a world of difference in ride . if you look/search here you will find how to relocate shock brackets .Look down in the FAQ down at the bottom of forum.
Hers the link http://67-72chevytrucks.com/vboard/s...d.php?t=451200
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
01-02-2017, 09:57 PM | #4 |
thanks for the info, so stock length shocks are fine as well as long as they are relocated?
01-02-2017, 10:42 PM | #5 |
That's what I did was going to replace them with shorter ones but they ride just fine and don't bottom out. I have ran them this way for a couple years now
01-02-2017, 11:04 PM | #6 |
Sweet , then when I want it lower I can just buy dropped spindles for the front and 2in blocks out back with a adjustable track bar
01-02-2017, 11:11 PM | #7 | |
01-02-2017, 11:12 PM | #8 |
