70 c10 with a Borg Warner
Hey there, I am fairly new to tranny and motor swapping.
I currently have a 93 454 Chev 4 bolt main in my 70 c10. It has a th350 behind it, and I can tell already it can't handle the torque (after 1000km). I bought a borg warner super t10, tail casting # 1304066903. From what I have found, this from 1977. I was told it came from a 455 trans am. It came with a hurst competition shifter, and a bell housing. How will I know if the bell housing will fit? Any other parts I will need to bolt up? Thanks for your help! |
![]() Join Date: Dec 2007
Re: 70 c10 with a Borg Warner
Small block and big block use the same bellhousing. A 621 bellhousing will work, it might be fun to find a used one however...
![]() Join Date: Aug 2004
If it is a BOP bell housing, it won't bolt up to your 454. Chevy has a different bolt pattern on the block.
But, you should be able to sell the BOP pattern bell for the same or more than what a used Chevy bell will run. BOP = Buick Olds Pontiac (and Cadillac)
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#4 | |
So, I'd check what bellhousing you have and not ASSUME what you where told it came from is correct.. It still might have the B.P.O. bolt pattern, if it was from a 77 t/a as they came with 400's and a stick.. but I'd check what you got.. |
hey guys, thanks for your help
The only serial # I can find on the bell housing is on the clutch fork. 14066235 |
Here's a link on the way to tell what bell you have.
https://www.teambuick.com/reference/ident_automatic.php |
Okay, so it is a BOP bellhousing. I could either sell it and look for another chevy one, or use an adapter?
Any downside to the adapter? Will the bellhousing from a th350 work with the trans? I currently have a th350 in the truck. |
#8 | |
The th350 bellhousing is not removable - cast as part of the transmission case. |
