64 gmc steering column issues
I have some serious flop in my steering wheel. needs lower bearing I'm guessing. horn does not work nor do the turn signals. I read somewhere that the 64 gmc uses 62 or 63 chevy column parts. is that correct? what parts do I need to order and where should I get them from to fix these issues? thanks
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
#2 | |
Re: 64 gmc steering column issues
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
just checked him out. turn signal canceling cam. he has three listed. one looks nothing like it. priced from $7.95 to $124.50
I have a 64 GMC also and yes the steering column parts are the same as a 63 Chevy. Seems they stayed with the older part one more year the Chevy did.
![]() Join Date: May 2007
GMC turn signal is different then a chevy turn signal so you have to be careful when ordering parts.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Classic Industry... I had the turn signal switch in hand and returned is as I ended up getting an Ididit column to go with my No Limit power rack
![]() Comparing it to the old one, it was correct. Part numbers are in the picture below. The wire location and the screw location near the turn signal are the major difference. The lower bearing is available. The upper bearing, with the horn contact are back ordered everywhere you may find them online, Impala parts places, truck places, etc. That lower bearing seems to be a bear to remove as you will need to take the column out, and pull the inner steering shaft down from the bottom and knock the bearing all the way to the top because of the rag joint flange, and then bang it all the way back down....etc. Just an FYI. Fitment on the switch is as follows, MP8685 - 1963-66 Without Tilt Wheel Plastic Turn Sign Switch Complete replacement self-canceling turn signal switch with correct connector and wiring colors to match up with your original. Applications: 1963 Chevrolet pickup 1963-66 GMC pickup 1963 Panel or Suburban Adam |
If you happen to just need the canceler....Classic site as well
1963 Full Size Chevrolet , 63 Truck Turn Signal Lever Cam Without Tilt Wheel CX1178 - 1963 Full Size Chevrolet , 63 Truck Turn Signal Lever Cam Without Tilt Wheel Cancelling cams are mounted below the cap but usually on top of the turn signal switch. When placed in its correct position, the cam will shut the turn signal off when the steering wheel is returned to the centered position. If your turn signals turn off prematurely or not at all then you'll probably want to replace the cam. Adam |
