01-03-2017, 10:10 AM | #1 |
Benefits from changing from 6 lug to 5 lug wheels?
I have a 67 Suburban C10 2wd. I'm looking at switch from 6 lug with drum brakes to 5 lug with disc brakes. Is there much of an advantage to go with 5 lug wheels other than there being more wheels to choose from? I'm looking to run a simple 15" or 16" steel wheel without a spacer.
Thanks, Nick |
01-03-2017, 10:44 AM | #2 |
Re: Benefits from changing from 6 lug to 5 lug wheels?
I'm also wondering if I do switch to a 5 lug wheel should I go with a 5x5 lug pattern or a 5x4.75?
01-03-2017, 08:00 PM | #3 |
On my 69 Burb I switched to a 15 inch 5x5 wheel. The only reason i see to go to 5x4.75 is if you are going to use Camaro or Corvette brakes.
Steven 69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners 2017 50th Anniversary Camaro SS 2004 Chevy Impala LS 2016 Chevy Malibu LT |
01-04-2017, 11:07 PM | #4 |
The only reason to switch is for variety of available wheels. The fewer lugs and the smaller the spacing, the lighter duty they are.
01-10-2017, 09:52 PM | #5 |
I personally see no need, and have no desire to switch away from 6 bolt wheels.
01-13-2017, 05:49 PM | #6 |
70+ ( Old Skool Club )
You can buy 6 bolt disc brake conversions discs form different suppliers. I know Early Classic Enterprises sells a 6 lug disc brake conversion kit.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-14-2017, 01:08 AM | #7 |
Just know that if you go with 6-lug disc brakes and you have stock 6-lug rims, they won't fit the disc brakes.
01-14-2017, 06:29 AM | #8 |
Rottenwood Garage Member
If you are happy with your 6 lug wheels and your drum brakes there is NO reason to get caught up in this 5 lug swap craze! There are disc brake conversions for 6 lugs but unless you are running a high HP engine the stock drums well adjusted and cared for are fine.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
01-15-2017, 08:00 AM | #9 |
Thanks for all of the replies and suggestions guys. After weighing my options I think I'm going to stay 6 lug for now. I've been looking at these wheels just wondering if they will fit properly. What do you guys think? Will I be able to add a factory style disc brake behind these wheels?
Also would you go 15" or 16" I'm not sure which size has more tire options. I'm looking at putting wide white on these wheels. https://m.summitracing.com/parts/usw-68-5860 Thanks, Nick |
01-15-2017, 02:23 PM | #10 |
Here they are in 17" they only make 15" and 17" in this wheel style.
https://m.summitracing.com/search/pa...%20wheels%2068 Last edited by nastety92; 01-15-2017 at 02:37 PM. |
01-16-2017, 09:51 AM | #11 |
So I ended up ordering one of the wheels today. I can test fit the one wheel and hopefully find some cheap tires to put on to test fit as well.
https://www.summitracing.com/parts/usw-68-8860 |
01-17-2017, 05:26 PM | #12 |
the only disadvantage to aftermarket 6 lug discs is that you cant run to autozone etc on a sunday and buy a new rotor...lots of us did our conversions back when there were no conversion kits
1970 short step c10 leaf spring 454 |
