Pedal height with power brakes
Hey all,
For those who have converted their trucks to power disc brakes, what did you settle on as a pedal height? I have a 1990 Tahoe booster and master cylinder combo. I know the eyelet on the booster push rod will need to be modified to the correct length, but I wanted an idea of pedal height. I think 5-6 inches would be about right. Thoughts? |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Pedal height with power brakes
Make it right for you.
Think about changing the bumper for the up-swing to the height you want it.
What ever works for you, there's no incorrect way as long as the pedal has enough room for full travel. On my 62 I thought the factory pedal height was actually quite good so I set it how it was from the factory, and then lowered the clutch pedal to match the height of the brake pedal
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
![]() Join Date: Jan 2011
I left mine at the stock height. I did re-drill the push rod location 1 inch lower.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
I agree with all the above.
![]() Caution: keep in mind the proximity of your brake pedal to your accelerator pedal--can be dangerous. Enjoy your work and when you get unsatisfactory opinions on here, make it fit YOUR tastes. ![]() Sam |
I didn't modify or drill anything
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
I agree with all that have commented, check it out for your self. BUT, if you need to, I took off my brake pedal arm, cut it and altered the angle then rewelded it. I was able to change the heighth without altering the brake pressure.
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
