![]() Join Date: Sep 2016
Drop rear leaf springs
My original plan was a flip kit on my 72 c10 but I have been looking at the 4 inch drop leaf springs but not sure which is the path to take. Any one know of advantages of either one???
#2 | |
Re: Drop rear leaf springs
Went with a 4" drop spring and 2.5" extended shackles. Obviously the truck isn't finished, but already thinking we should have flipped it instead. I had to buy springs either way and didn't feel great about spending the money for new stock height springs and then for flipping. If you already have springs, I would definitely just go with a flip. |
Thanks for the info, I'm guessing these are really old springs so I'm going to bite the bullet and replace them with new stock and do the flip, I could always put shackles on it if I need it lower. Thanks
#4 | |
If you flip you can do blocks to lower it further if necessary. Makes it nice that way because you can tailor it to your tastes. |
Well, how low do you want to go? My 69 short step has factory HD rear leafs. The flip dropped the rear 7 1/4". If that's not how low you want to go, then buy drop springs.
I'm pleased with how mine came out and would flip again.
