Old 01-03-2017, 09:46 PM   #1
rigid
4x4 front differential seal
Front seal is leaking . somewhat mechanically inclined and think I can fix it on the ground but have a couple concerns . If I can break the nut loose with a breaker bar and get the seal replaced do I just torque back to spec and if so what is that ? do I have to be concerned with too much or too little crush like on a 9" ford pinion nut ?
thank you
rigid is offline   Reply With Quote
Old 01-03-2017, 10:55 PM   #2
wildwilly4x4
Re: 4x4 front differential seal
yes you will have to be careful about the crush sleeve. I have changed many out and its not really a big problem. Ideally you should replace the crush sleeve each time you take the torque off of the yoke, but I don't think you will have any problems just swapping the seal and putting the yoke back on.
wildwilly4x4 is offline   Reply With Quote
Old 01-03-2017, 11:52 PM   #3
vht
Take a chisel and make a mark on the pinion and the nut before you loosen it. When you put it back, align the marks.
vht is offline   Reply With Quote
