Old 01-03-2017, 09:48 PM   #1
Smniekamp
Smniekamp's Avatar
All my plugs are fouled?
1981 Chevy K20 350 with 4 speed manual 4x4 (70,000 on rebuild) stock.
Hey guys,
I was driving down the road when all of the sudden I felt a miss. The truck hesitated then kept running, about 200 yards later it started to miss really bad. It felt like a automatic trans that was about to die, slipping in and out of gear (however I have a manual). I ended up having to tow it home. It will start and run very rough, stumbling hard and missing. I can step on the gas and bring the rpms up to around 2500 and it will run a little better (less miss fires), but then will just completely cut out and die instantly. It almost sounds like its firing on half its cylinders. I threw a timing light on it and the mark jumps around on me a little. Ive replaced the plugs, wires, ICM, Coil, cap, rotor, fuel pump, accelerator pump in carb, checked the pcv valve, and checked to make sure rotor is turning (stripped dizzy gear). Still having the same issue.... Any other ideas? All my plugs were fouled when I pulled them out initially. Could a leaky intake cause all the plugs to foul? Head gasket? Any input would be awesome! Thanks!
Smniekamp is offline   Reply With Quote
Old 01-03-2017, 10:09 PM   #2
Alex V.
Alex V.'s Avatar
Re: All my plugs are fouled?
What color/consistency was the fouling?
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 01-04-2017, 08:34 AM   #3
cadillac_al
My first thought was the float level is getting too high. It will usually leak out the vent if it gets high though. Is it a Qjet? Is it blowing black smoke? This is when it's nice to have a spare vehicle to swap a distributor or a carb with a known running one.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 01-04-2017, 01:04 PM   #4
4x4chase
What your describing sounds like the timing chain skipped? Threw everything off. Can you get #1 to TDC and pull a valve cover to verify the valves are closed?
4x4chase is offline   Reply With Quote
Old 01-04-2017, 02:25 PM   #5
Dead Parrot
Was the timing near normal even if unsteady? Thinking if the timing chain jumped, the timing would be way off.
Oil pressure normal? Since the oil pump is driven by the distributor, if the cam/distributor gear stripped, should adversely impact oil pressure.
Brakes working normally? If power brakes, maybe the booster developed a bad leak.
Bad gas?
If mechanical fuel pump, check the pressure. Maybe the cam lobe that drives the pump push rod died.
Do check the float/seat setup. It only takes a speck of crap to cause a flood condition in the carb.
Dead Parrot is offline   Reply With Quote
Old 01-04-2017, 04:19 PM   #6
tucsonjwt
If fouling is black carbon, then it is running too rich.
If fouling is oil, then rings are shot.
tucsonjwt is offline   Reply With Quote
Old 01-04-2017, 07:40 PM   #7
Smniekamp
Smniekamp's Avatar
The timing was close to normal (aside from the variation that I saw). Oil pressure is still good. I haven't checked the brakes but did notice that the bottom of the booster showed signs of a possible leak, it appeared to be damp on the lower section of the booster. What would this mean, vacuum leak? The gas is good and I just had the carb apart (Qjet) a couple weeks ago to replace the accelerator pump. May just go ahead and do a whole rebuild on it. The plugs looked more oily than carbon build up. They were dark black and wet. Im not getting a noticeable amount of black smoke out the tail pipe. It has a mechanical fuel pump as well... really hoping the cam didnt take a dump on itself...
Old 01-04-2017, 11:01 PM   #8
100%Chevy
Maybe there's trash holding the needle open making it flood.
Wet,black plugs is usually gas fouled.
Could also be a bad float letting it get too much gas.They're only about $6.00 new at the parts house.
Mike.
100%Chevy is offline   Reply With Quote
Old 01-11-2017, 02:54 AM   #9
El Dorado Jim
any update?
El Dorado Jim is offline   Reply With Quote
Old 01-11-2017, 06:51 PM   #10
Matt Man
Matt Man's Avatar
I recently had the same problem....turned out my float level was way to high. The only thing I can think of is that my fuel filter in the carb fell apart and messed it up?
I would check the float level.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 01-11-2017, 07:26 PM   #11
100%Chevy
This new govt.corn gas will dissolve the rubber and glue holding the paper element fuel filter together!
Already happened to 2 of mine.
Mike.
Old 01-11-2017, 07:45 PM   #12
Matt Man
Matt Man's Avatar
Mike.
THIS!!!!! so irritating that a 3$ part messed up my carb, I'm replacing twice a year now.
Old 01-12-2017, 03:22 PM   #13
Smniekamp
Smniekamp's Avatar
Hey guys, so I live in Alaska and its been -8 for about a week and a half. Once it warms up above 0 Ill get back at it! Im going to check to see if my brake booster is leaking first. It looks wet on the bottom like fluid is leaking out of it? Online a guy said that its a sign of a failed booster which causes a huge vacuum leak, anyone agree with that?... If its not that then Ill check the carb filter, I replaced the filter a month ago but you never know. Thanks for the continued help. Ill post another update as soon as I can!
Old 01-12-2017, 05:07 PM   #14
jjzepplin
jjzepplin's Avatar
You could easily block all the vacuum connections to the motor and see if the symptoms still exist. Reconnect one by one and find the issue. Back when I smoked I would light one up and blow smoke through an open vacuum line and find the leak. Now I have to do things the hard way.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 01-29-2017, 08:41 PM   #15
Smniekamp
Smniekamp's Avatar
Bad gas?
So it finally warmed up to 14 degrees today. I went out and plugged the vacuum line that goes from the carb to the brake booster and tried to start it. With a little stumble she fired up and ran GREAT! Looks like my brake booster is the problem (vacumm leak)! If it was you would you replace the booster and the master cylinder at the same time? Thanks for all the help guys! Glad to have my '81 running again!
Old 01-29-2017, 08:56 PM   #16
Nick_R_23
Nick_R_23's Avatar
Hey, cool to see another Alaskan on here! If your brakes work and feel solid and not spongy, I would leave the master cylinder alone, no need to replace it, it's working fine.
Old 08-02-2017, 03:03 PM   #17
Harley03joe
I Found These Plugs On Ebay >>LEONARD OIL FIRING LR14 mm SPARK PLUG Also In 18 MM
What MM Is A 5.8 K Eng In A 1987 Chevy Silverado
Thank You
Harley03joe
Harley03joe is offline   Reply With Quote
Old 08-02-2017, 04:25 PM   #18
RotaryRocketeer
RotaryRocketeer's Avatar
Thank You
Harley03joe
You should probably start a new thread for this.
RotaryRocketeer is offline   Reply With Quote
