01-03-2017, 10:11 PM | #1 |
New Carb will only accelerate
New here, just posted in the welcome section.
I have a 71 C10 with a 350 and a Rochester Quadrajet. I have installed a new carb and when I start up the truck it just accelerates and the pressure rises. Any ideas? |
01-03-2017, 10:50 PM | #2 |
Re: New Carb will only accelerate
If you mean the engine just races & won't return to idle, It could be the linkage needs adjusting or the secondary throttles are not closed.
01-03-2017, 10:52 PM | #3 |
I am new to carbs. I looked over all of the linkages but not sure what would need adjusted.
01-03-2017, 10:57 PM | #4 |
I think there should be a return spring pair, there is on my 1969 truck with Quadrajet.
01-03-2017, 10:59 PM | #5 |
I have a return spring on the drivers side and a divorced choke coil spring on the passenger. I did replace both of those.
01-03-2017, 11:01 PM | #6 |
Take a pic of both sides of your carb.
Otherwise it's just a guessing game. |
01-03-2017, 11:17 PM | #7 |
OK here is each side.
01-03-2017, 11:30 PM | #8 |
Try turning down the high idle.
It's a phillips head screw right under the choke vacuum pot. |
01-03-2017, 11:32 PM | #9 |
OK I think I saw that today. I will try that tomorrow. Thanks.
01-03-2017, 11:35 PM | #10 |
20' Daredevil (Ret)
Maybe this will help https://www.youtube.com/watch?v=qmFCh8LhRrU
01-03-2017, 11:37 PM | #11 |
And your kickdown cable is on the wrong hole. It needs to be where your spring is. And your spring goes where you have the kickdown.
Then your spring will work better. |
01-04-2017, 12:26 PM | #12 |
The Older Generation
Yup, no tension on the return spring.... LockDoc
01-04-2017, 01:01 PM | #13 |
Are you letting it warm up and it's still doing it? That's how carbed vehicles warm up, they have a choke/fast idle, it can take a few minutes when it's cold for the idle to drop to normal.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
01-04-2017, 05:00 PM | #14 |
What part of town are you in? If you can't get it worked out, I might be able to stop by & take a look at it.
George |
01-04-2017, 05:09 PM | #15 |
Whats up with the vacuum hose going between manifold and ported vacuum over the fuel inlet?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
01-04-2017, 05:52 PM | #16 |
trucks72
I think his kick down cable is in the right spot. His spring is just to long to give any tension. Just needs a shorter spring.
01-04-2017, 11:46 PM | #17 |
Yeah, I agree- I can't quite tell from the photos but if you ARE connecting your ported and manifold vacuum ports on the front of the carb... that's going to be a problem.
Josh '70 Custom Camper / 20 |
