Old 10-13-2003, 07:04 PM   #1
crazy longhorn
Fabricate till you "puke"
Yikes!
My old longhorn is down for the season, while i work on rear suspension. The exhaust was unbolted & stood against the wall......well, we all have to" Lite" them with open corks. Well, there is a crazy "angel" that rides on the crazy old man's shoulder! That 383 was warming up @ a fast idle, & i noticed something dripping on the floor....GAS! The fuel pump is under the cab, about 2 ft from the "fireballs" ,when the headers are open well, you can probably guess that I "chilled" it d@mn quick the fire stayed in the eng & pipes, but the tank & all is out of the truck! Dammit, I keep saying 1 thing at a time.....but this one is going fuel cell before next season! anybody in Ill , or close need a good tank? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-13-2003, 07:07 PM   #2
jamis
F.A.S.T. president
jamis's Avatar
fire in the hole........glad this story didnt end in a sad note
jamis is offline   Reply With Quote
Old 10-13-2003, 07:55 PM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
Glad that drip didn't turn into an inferno!
At least you now have a good excuse for a fuel cell
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 10-13-2003, 08:53 PM   #4
crazy longhorn
Amen, fire is cool......but not on the truck! in almost 20yrs, I have not had that truck on fire. i have had a few others on fire tho if you ask any man with a torch in his had "did you lite that on fire"? If he says no, he is a d@mn LIAR! fire is pretty crazyL
Old 10-13-2003, 08:59 PM   #5
Denny
Denny's Avatar
Ack that was close, glad you are alright.
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End
Early Classics 6 Lug Disc Brakes and Spindles
All Stainless Lines
Denny is offline   Reply With Quote
Old 10-13-2003, 10:04 PM   #6
racedvl
racedvl's Avatar
whoa!!!
racedvl is offline   Reply With Quote
Old 10-13-2003, 11:36 PM   #7
dinnut
dinnut's Avatar
that sounds like it could have been bad. but awesome by the same token.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
