10-13-2003, 07:17 PM | #1 |
3/4ton to 1/2ton
i was just wondering if a 71 3/4 ton front Suspension will work on a 71 1/2ton frame they both have front disc brakes and the 3/4 ton has power brakes i want to kept the 1/2 ton 5 lug but i was wodering if the a arms and every thing else will work on the 1/2 ton thanks Travis
71 Chevy C/10 lwb 350 5 speed nv3500 3.73 rear end 2.5" Front Drop and 4" in the back Edelbrock perfomer rpm manifold Edelbrock 600 cfm carb Headmen headers |
10-13-2003, 07:35 PM | #2 |
Fabricate till you "puke"
you are 71 1/2 ton discs.....but not power? If you swap the master, & add the booster you will be good to go. dont mess with the C 20 front suspension, its 8 lug on the wheels. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
10-13-2003, 07:57 PM | #3 |
my Suspension on the 1/2 is kinda messed up on the driver side and i was wanting to know if the a arm a differant the frame is allso bent but that is geting fixed and i just dont want to spend that much money and time to replace the front end yet with new parts thanks
10-13-2003, 08:01 PM | #4 |
the3/4 top arms will bolt the 1/2 ball joints, but the bottom arms will not press the balljoint. The ball joint is larger dia on the 3/4 ton ........crazyL
