01-04-2017, 10:29 PM | #1 |
Clutch advise
Hi all, Mike here in Tracy California.
I have a 1971 c10 lbw base model 3 on the tre 250 6.engine. Does anyone have part numbers for the "long and short" through out bearings. I though I had a clutch issue as rod adjustment is way to the end of the rods end, thread wise . Looking at the pressure plate edge on it has same thickness as the New kit I got from oriely auto. And there was a thread about out of adjustment being the fault of the different t o bearing. Ideas? Cheers Mike |
01-04-2017, 11:10 PM | #2 | |
The Older Generation
Re: Clutch advise
Welcome to the board Mike. The pressure plate and flywheel usually don't wear that much. The clutch disk is what wears and it doesn't take a lot of wear to make a big difference it clutch travel. If the throwout bearing isn't turning it will wear the face of the T.O. bearing and the pressure plate fingers. There is quite a bit of difference in the throwout bearing length between long and short. Do you know which pressure plate you have now, Diaphram or Borg & Beck style? You have to use the short T.O. bearing with the diaphram pressure plate and the long T.O. bearing with the Borg & Beck pressure plate..... LockDoc
01-06-2017, 08:34 AM | #3 |
Re: Clutch advise
The kit comes with the diaphragm type as far as I can make out.
To get more free travel in the pedal nuts in or out? I have less than one inch to end of rod. Cheers Mike |
01-06-2017, 10:29 AM | #4 | |
Re: Clutch advise
You would have to shorten the rod length to get more free travel so the nuts and centering spacer/pivot would have to screw on the rod more. It doesn't take much to make a lot of difference so only go one or two turns at a time LockDoc
01-06-2017, 11:34 AM | #5 |
Re: Clutch advise
If you bought the clutch kit it will have a matching TO brg. Your linkage may be worn at the pivots causing excess play & adjustment.
