Old 01-05-2017, 04:52 PM   #1
67 cst swb
67 cst swb's Avatar
2001 3500 Dually Lowering ?
Anyone in here have any experience or pictures of a 2001-2002 (or 2003-2007) 3500 dually that has been lowered. I don't want to go too extreme as I still will use this to tow and haul. I want to avoid air suspension also.
Its a 2wd but this thing looks like a 4x4.
Thoughts?
Input?
Ideas ?
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 12-25-2018, 02:19 PM   #2
67 cst swb
67 cst swb's Avatar
Re: 2001 3500 Dually Lowering ?
Anyone ?
My Trucks:
Old 12-26-2018, 03:45 AM   #3
EVRLET
EVRLET's Avatar
Maybe you’ve seen this article before:
http://www.stylintrucks.com/articles...hevy_3500.aspx
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
Old 01-02-2019, 03:07 PM   #4
DieselSJ
Go with air - you won't regret it.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 01-04-2019, 08:35 AM   #5
77c10bowtie
77c10bowtie's Avatar
when it comes to the 99-07 trucks 3/4 and 1ton I perfer DJM suspension. they make nice stuff that bolts together well and holds together. I have a 4/6 drop on my 4x4 duramax drag truck and it has held together really well and rides nice too.
how much do you tow? you can still tow with a significant drop but youll want the right helper bags to compliment the system. dont just go all air ride you need some form of spring if you tow heavy.
77c10bowtie is offline   Reply With Quote
Old 01-07-2019, 05:01 PM   #6
SCOTI
SCOTI's Avatar
Thoughts?
Input?
Ideas ?
Spindles or drop springs up front. Shackles or shackles + hangers for the rear.
Add an AOL kit if you need more drop but want to ensure it maintains it's hauling capacity.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-08-2019, 10:01 AM   #7
77c10bowtie
several companies make lower control arms that lower the front, better than spindles. spindles take your tierod angle way out of spec and cause some weird steering when towing. the 1999+ trucks have torsion bars so they wont have coil springs so imo the best option is a lower control arm.
i have DJM lower control arms that dropped the front end 3" on my 2500HD
for the rear i did shackles and hangers, id start with shackles first though and decide how low you wanna go.
Old 01-08-2019, 11:31 AM   #8
SCOTI
SCOTI's Avatar
My bad..... I have a '99 3/4 ton & was thinking the suspensions were the same through '01 on the HD trucks.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-08-2019, 07:42 PM   #9
77c10bowtie
Maybe it is 01, the Duramax diesel came out in 01 so that's when everything changed.
Old 01-13-2019, 02:31 AM   #10
95 S_Trucker
95 S_Trucker's Avatar
The 2500(8600 GVW) 2wd had coil springs. The 2500HD/3500(9200 GVW+) 2wd had torsion bars
95 S_Trucker is offline   Reply With Quote
