01-06-2017, 02:52 PM | #1 |
Cab support replacement ??
So i am finally ready to bite the bullet and replace my cab supports/bushings and sections of floor that need it. They are way far gone. My question is if anyone has ever attempted to replace these while NOT fully removing the cab from the frame. I would like to support the cab from the rockers with jackstands on 4 corners with some continuous support after i lift it up only about an inch or so off the frame/mounts. I will have the front end sheet metal off but the rest of the cab is in decent shape so i dont want to fully blow the truck apart (again). I am pretty crafty and do most work alone.
Thanks in advance for ideas and suggestions!
1969 Chevy K20 Longbed |
01-06-2017, 07:27 PM | #2 |
Re: Cab support replacement ??
I did mine a while ago with out removing the cab from the frame. It was not a problem. I loosened all the bolts and used my floor jack at each corner. Took an hour or so. And this was with all the sheet metal on the front in place.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
01-06-2017, 07:40 PM | #3 |
All about them K’s
I replaced my front pans and the outer sections as well as the floor supports with the cab on. The floor supports are kind of a pain with it on but it's certainly doable.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
01-08-2017, 10:07 PM | #4 |
Thanks for the response guys. I figured someone out there has done it before and while it may not be the easiest i think its the way to go for me.
01-08-2017, 10:36 PM | #5 |
done mine that way to piece of cake
