Old member
The ramp rat has a old hard lined brake controller in the cab. There is no wires hooked to it. It's tied into the brakes at the proportioning valve. I just finished adding a booster to the drum brakes and want to fix the E brake in this truck.
Does anybody know of something I can put on the old brake line in the cab that would put pressure on the system to use it as a E brake? You can see the one brake line that runs into the cab. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Question for you all????
Sounds like a line lock what you're looking for. Not to say it's a perfect substitute for a mechanical brake, but it should accomplish your goal.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
I would get rid of that hard line, plug it off and hook up the manual,cable ebrake
#5 | |
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Old member
So all I would need to do is take the line loose for the rear brakes at the proportioning valve and run it inside the cab to that valve (picture) and plug off the regular one at the proportioning valve. That shouldn't be to hard to do.
Are do you think I need to use the regular spot on the proportioning valve for the rear brakes and just cap off the old trailer brake line? This valve would let me set the brakes and let off the pedal the brake lights should not stay on either. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 01-06-2017 at 07:22 PM. |
![]() Join Date: Dec 2013
That looks like a line installed aftermarket for trailer brakes ? What's in the truck now as far as a stock parking brake ?
Posted via Mobile Device |
I used to drive tow truck some time ago and we used to have those to lock the wheels to help on winch outs . they were constantly in need of rebuild or replace due to internal leaks I don't think I would trust them to use as a parking brake . but if you must try tow truck supplies maybe they improved them over the years been 15 or so years from last time I drove for a living
![]() ![]() Join Date: Sep 2008
This, or some version of it is what we use on dump trucks, fork lifts etc.
http://www.ebay.com/itm/Mico-02-640-...-/171523661070
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
I used to work on ground support equipment and about 80% of our equipment used Mico (Wabco) brake locks similar to the one davischevy posted. Kind of expensive for an individual to buy over the counter but they are very reliable and can hold a 100k pound push back tractor! They make them in lots of different flavors. They used to make one that you can lock with a key.
Also if you want to be like all the cool kids, you can look up the hydraulic brake levers that they use in rally and drifting cars.
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten. |
#11 | |
Old member
![]() Quote:
I have nothing as of right now. I would love to have good e brakes but don't know nothing about these big trucks. I don't know if I can find cables for them. It has the old hand brake lever in the cab but nothing is hooked to it under the truck. Yea I saw where it said not to be used for a e brake. ![]()
