Old 01-06-2017, 08:38 PM   #1
catch2otwo
Suburban body interchangability
I have a 73 burb that has pretty bad roof rot. Found an 84 body with very minimal rust for free locally. From my untrained eye, the bodies look the same, i plan on putting my doors into this body. Will everything be good, or is this deal too good to be true?
catch2otwo is offline   Reply With Quote
Old 01-06-2017, 11:47 PM   #2
Edahall
Re: Suburban body interchangability
Yes, the bodies are the same except the front end sheet metal is different.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 01-06-2017, 11:48 PM   #3
kwmech
They are both the square body design, only real difference being the front clip. Frame mounts should all be the same, even up to 1991
Old 01-07-2017, 01:10 AM   #4
catch2otwo
freaking awesome. thanks guys
