water pump bearing
i have a issue when my truck is cold first starts up it makes a chirp noise like a dry bearing or rubbing noise, then goes away after 5 mins started.
this the sign of a wearing out water pump bearing? may need to replace it anyway come summer this unit here looks like it will do just fine. http://www.oreillyauto.com/site/c/de...patibilityTab_ |
Re: water pump bearing
noise sounds like it's coming from this area
or could it be the fan clutch? |
![]() Join Date: May 2006
I think you've got another problem besides the water pump; probably the fan clutch or one of the idler bearings. When the water pump starts going bad you get some movement and leakage on the shaft. Look for leakage at the weep hole at the bottom of the water pump. That's a possible trouble indication. Take the fan belt off and spin/ rock all the spinning components in this area for looseness, roughness, including the alt. The alt. bearings have made the noise you're talking about in my personal experience of owning SBC-equipped vehicles for 40+ years.
1989 K1500 Chev. EC Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit. 2009 Hummer H3T 3.7L 5M (sold) 1997 K2500 Chev. EC 7.4L/ 4L80E (sold) 2018 Dodge Ram 2500 HD R/C |
#4 | |
so i suspect fan clutch or water pump bearing yes i will go through and check for play and any roughness. checked weep hole no leakage when i replaced radiator hoses. i have a feeling its the fan clutch bearing , i will replace it all come summer. thx for reply |
many miles can a water oil pump go before bad?
my trucks only done 68 000 |
I think I went through a couple of AC Delco water pumps when my truck was new. I found that unusual because I've seen a lot of them that have lasted as long as the engine. I've used Edelbrock water pumps almost exclusively since then in my trucks. I still use AC Delco in my LS engine but that's a different animal. My last engine swap I had 190K on the engine and the same on the Edelbrock wp. Since that time I've got 50K on this combo with no problems. But your question I think you should still be good unless you have some serious corrosion in your cooling system.
yep corrosion the old man had the truck never maintained it well
i flushed the system good and its all new again, took radiator right out flushed it well. |
i have a feeling its the fan clutch though, but am going to replace the whole system come summer.
Rollin' Old Skool
Just a little something for you to read through...it's something I dealt with on/off randomly for almost 2 years:
http://67-72chevytrucks.com/vboard/s...d.php?t=607963
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
new water pump kit came dang it's heavy , amazed the 4 bolts hold it in place..
still to install it. |
| Bookmarks |
