01-07-2017, 10:30 AM | #1 |
Removing the bow in the hood
I have a 79. Hood is bowed and it is time to try to remove this. The plan is to grab some small pieces of 2x4s and put one on top in the middle. Two on the bottom. One front and one back. Take a long 2x4 and place in the bottom and squeeze. It will hiperextend the hood just enough to make it straight when done. Thoughts? I may make some relief cuts in the side support of the hood and weld back when done
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
01-07-2017, 10:35 AM | #2 |
Re: Removing the bow in the hood
Look close and you can see what I am dealing with
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE Last edited by chrismoore701; 01-07-2017 at 10:49 AM. |
01-07-2017, 10:51 AM | #3 |
For some reason I can't load the photo. But you guys know what I'm talking about. Just a slight bow. Nothing extreme
01-07-2017, 01:16 PM | #4 |
Here we go. Check out the slight bow
01-07-2017, 04:11 PM | #5 |
I don't know about that 2x4 on the top, might scratch it. I would stack 2x4's on the core support and find a fat ass to sit on the bowed part.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
01-07-2017, 08:16 PM | #6 |
You won't need relief cuts, just luck. It will be hard to straighten out without paint or body damage.
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban |
01-07-2017, 09:16 PM | #7 |
I have a spare hood that needs some work and I would have to paint it. That is if the repair on my other hood fails. I just don't want to spend the time and money to paint it. Wish me luck. Going to tackle it next week
01-07-2017, 10:11 PM | #8 |
Diggin The SquareLife
Jump on it
01-08-2017, 12:02 AM | #9 |
Thanks guys
01-09-2017, 12:16 AM | #10 |
Bow is gone
01-09-2017, 12:24 AM | #11 |
Post Whore
Do you have the hood stiffeners? If not it will help keep that from happening again
01-09-2017, 12:37 AM | #12 |
New hinges make a world of difference, also lube them at least quarterly and it will never be an issue again.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
01-09-2017, 01:02 AM | #13 |
Hood stiffeners also destroy the design of the hood to fold in the event of a crash. The hood then has no where to go but push through the windshield.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
01-09-2017, 08:55 AM | #14 |
Hood Stiffeners are not an option. I have two little boys and they need their daddy to stick around for a little while. Where is the best place for hinges? I buy 90% of my parts from classic parts. Is this a catalog order or OEM order?
01-09-2017, 05:19 PM | #15 | |
Aftermarket hood stiffeners were advertised in off-road magazines as early as 1974, and in all that time since then the NHTSA database reports no incidents resulting from killer hoods.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 |
01-10-2017, 05:12 AM | #16 |
Could be a possible episode for the myth busters.....square body decapitations by hood.....myth or plausible.....hmmmmn....
01-10-2017, 08:33 AM | #17 |
My kids are worth a bow
01-10-2017, 09:17 AM | #18 |
I have the same issue with a cowl hood, I am too scared to try what you did.
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532 |
01-11-2017, 11:01 AM | #19 |
Does anybody know a good place for the hinges?
01-11-2017, 11:33 AM | #20 |
http://www.truckandcarshop.com/trucks73_91/t73_076.html
https://www.brotherstrucks.com/73-80...tinfo/HNG73RP/ http://www.usa1industries.com/search...ts_per_page=50
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR Last edited by TKCR; 01-11-2017 at 11:38 AM. |
01-11-2017, 11:54 AM | #21 |
probably a dumb question, but are there any of these aftermarket hinges that are better than another?
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
01-11-2017, 12:15 PM | #22 |
I dont understand why sometimes they only produce one side. The truck shop has an original GM hinge but only right side. what the heck. not the first time either. Just looked and it seems to be discontinued. But still not the first time I have seen this issue
01-11-2017, 12:16 PM | #23 |
Personally I couldn't say. But I do know that a lot of these places, source their parts from the same places. Now the Truck and Car Shop, actually had one side that was a NOS part. If it was me, I would get a NOS part and the aftermarket one, then you could compare them. There may not be any difference in the 2 parts.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
01-11-2017, 12:18 PM | #24 | |
01-11-2017, 10:23 PM | #25 |
What did you end up doing to get the bow out? Any damage?
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
