Project Old School
I've had my eye on this truck for years but my neighbor would never sell it. It has set for nearly 10 years partially finished just rusting away. A few weeks ago he decided to part with it so I snatched it up. The cab is bad but not un-salvageable, the doors are rusted beyond repair and the frame is pretty crusty. I'm a big Off-Roader and love to "Crawl", I've wheeled an XJ for years but have always wanted a Full Size one ton Crawler. So it begins.
This is where it has sat for the last decade. |
Re: Project Old School
Loaded and on it's way to its new home.
Got it in the garage and got the cab and clip off and on a dolly. Took me an entire day to get the decals off it. The rear glass had been painted black with a rattle can.
The frame was a concern to me and after reading alot of builds here where members have used NBS frames. So I found a rust free 02 Silverado 2wd frame. Since I'll be hanging a Dana 60 up front all the IFS gets cut out anyway.
Here are the axles I'll be using, 79 HP Dana 60 and 14 Bolt rear.
Got the cab and front clip mounted on the 02 frame. With this being a crawler I need a low center of gravity. So I have to keep the cab within 2 inches of the frame rails. This is going to be a challenge with the front clip and bed.
I needed to make sure the 02 frame was going to work for me before moving forward. To get a visual of a final product I raised the frame to ride height of 22 inches above the frame rails. I'm going with a 116 inch wheelbase with 43 inch tires. I got the body sitting on the new frame and feel confident I can make all the mounts work, this is what my final mockup looked like. (the rims inside the tires are just so I couldnt see through, I'll be running re-centered H1 rims)
This is how the front will look sitting at ride height.
Finally got the coil springs out without killing myself, I really do dislike using spring compressors. But the good news is I got a pretty big pile of IFS junk started.
![]() Join Date: Jun 2009
Cool build my friend, so you basically just bought this for the cab and front clip ?
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
Picked up this 03 HD truck the other day, the plan is to stuff the 6.0 and 4L80e between the frame rails of Project Old School.
cool
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#13 |
I traded a Jeep that I paid 250 bucks for this truck so I don't have a lot in it. But yeah I'll just be using the cab and the front clip.
#14 |
I got the 6.0 and 4l80e pulled from the donor truck and dropped into it's new home. I was hoping to use the 6.0 frame mounts but they did not work with the 2wd 4.3 frame. I'm picking up a set of 2wd 5.3 mounts this evening that should let me bolt this thing in so I can get started on cab mounts.
#15 |
A few pics
#16 |
I got the engine bolted in last night and that allows me to get the core support location. Next I'll hang the fenders so I can pinpoint the cab mounts location.
#17 |
So my plan is to use the entire LS harness to include the cab harness, cluster and column. For those who have done this I would appreciate any "Lessons" you wish you had known ahead of time. Thanks in advance.
#18 |
Had a bit of a setback last night but in the end it all worked out. When I tried to add the fenders my core support was 2 inches too tall. I just couldn't figure out how my mock-up could have been that far off. So I decided to go back to plan A and use the C10 core support. After mocking everything up I started measuring for the radiator it occurred to me what happened. When I did mock-up I used the core support from the 6 cylinder truck but I mounted up the HD core support. HD trucks bodies set 2 inches higher so some quick measurements and I was back in business. I had to modify the fan shroud but other than that I got it all mounted up. Today I hope to have the cab mounts finished up.
#19 |
So I've finished up the cab mounts as well as the steering column, pedals, seat and gauge cluster.
