01-07-2017, 05:27 PM | #1 |
Why is my alternator working?
I noticed my aftermarket voltmeter reads a little low compared to the battery, especially when the fan is on high, so I decided to have a look at the alternator wiring. I don't quite understand, the alternator is unplugged but it seems to hold steady at the battery around 14 volts. Does anyone understand what is going on here?
Truck is a 72 K10, engine is now a 396. I bought it like this, so I can't say much about the history. Where is the main junction usually located on these trucks? I would like to get the wiring correct, have the charge wire going to the main junction through a fusible link and a charging wire from the junction back to the battery with another fusible link. Thanks! |
01-07-2017, 05:41 PM | #2 |
Re: Why is my alternator working?
See that big red wire? That's where power comes out.
01-07-2017, 05:45 PM | #3 |
01-07-2017, 05:54 PM | #4 |
All about them K’s
Looks like a gm one wire alternator to me. It's internally regulated and capable of sensing without the plug.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
01-07-2017, 05:58 PM | #5 | |
if i want to go back to a three wire, can i just remove the black plug and put the connector back in? assuming the two wires to the pigtail are ok, i mean |
01-07-2017, 06:14 PM | #6 |
All about them K’s
I went with A delco 10si on my k20. All I had to do was jump a couple wires down in the factory external regulater harness. It bolts in and the plug worked just fine.
01-07-2017, 06:16 PM | #7 |
01-07-2017, 07:00 PM | #8 |
If it's working why not just leave it alone, 14 volts is pretty good.
01-07-2017, 07:43 PM | #9 | |
Oh, yeah - where is the main junction on these trucks? Where did the factory sensing wire come from? |
01-08-2017, 11:20 AM | #10 |
I think the sensing wire goes to the horn relay, most 60s GM stuff is that way as I recall.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
01-08-2017, 07:11 PM | #11 |
