Old 01-07-2017, 09:48 PM   #1
tdangle
tdangle's Avatar
Center AC Vent Mod
I finally got everything hooked up and working, except the AC itself. I did the center vent mod which only uses 1 inlet hose. Not really working out. It blows a good amount of air to the driver, but none to the passenger. Side vents work as expected.
Guess next time I take the dash apart, I'll put the dual feed housing back in.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 01-07-2017, 09:58 PM   #2
projectking
projectking's Avatar
Re: Center AC Vent Mod
Thanks for the info, I'm putting together a collection of AC parts and will keep this in mind.
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 01-08-2017, 10:32 AM   #3
Katrina/10
Katrina/10's Avatar
I did mine that way too, didn't bother me too much since nobody sits in the middle.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 01-08-2017, 01:10 PM   #4
B. W.
B. W.'s Avatar
I'm mulling over the same thing, I'm an A/C hog, I always turn the vents toward me (selfish huh!) So I'm thinking this might work out in my favor?
B. W. is offline   Reply With Quote
Old 01-08-2017, 02:11 PM   #5
Katrina/10
Katrina/10's Avatar
It greatly improves the airflow to the driver, nice when it's really hot in the summer. I just did it that way to simplify the air hoses in the dash, but it does have a side effect.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 01-08-2017, 06:51 PM   #6
tdangle
tdangle's Avatar
I plan on getting my AC working prior to summer. If I want my wife to ride as passenger I must do all I can to keep her cool. So, I'm going back to the original setup. You know what they say... Happy wife, happy life!
Terry
Old 01-08-2017, 09:59 PM   #7
jeffahart
jeffahart's Avatar
I did the mod because of limited space behind and around the original AM radio. I hated the Mod. I installed a retro sound. Now there is enough room behind my dash to park a bus! I re-plumbed center vent to blow out evenly, much better that way. But, hose wrestling around the stock radio is no fun either.
White K20
jeffahart is offline   Reply With Quote
Old 01-08-2017, 10:11 PM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Center AC Vent Mod
As long as cold air is blowing out the center vent who cares! It blows straight out no matter how it's ran!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-08-2017, 11:13 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Just swap the hose/plug to the other side
Like Andy said, cold air is cold air. If the AC works that's all that matters, the cab will stay cool no matter how the air is directed.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 01-09-2017, 08:10 AM   #10
Andy4639
Old member
Andy4639's Avatar
Talking Re: Center AC Vent Mod
Center vent.
Outside temperature!
Old 01-09-2017, 11:27 AM   #11
jeffahart
jeffahart's Avatar
This is not correct.
White K20
Old 01-09-2017, 11:34 AM   #12
Andy4639
Old member
Andy4639's Avatar
So your saying it doesn't come straight out? Mine sure does. The air comes into the center vent from the side one are the other and hits the other side then comes straight out the vent looking at you.
But I really don't see how it's not enough cooling to begin with when you haven't changed the capacity of the unit.
All you have done is restricted the flow.
Old 01-09-2017, 11:37 AM   #13
67 chevelle
67 chevelle's Avatar
If you dont smoke just put it where the ash tray is , Im sure someone has done this on a retro ac install
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 01-09-2017, 12:42 PM   #14
jeffahart
jeffahart's Avatar
If you do the mod of the OP, which is the mod I did. Plugging one hole and using one hose, then the air flows in the direction the single hose is pointing. It's a dysfunctional mod. I did not like it. I agree, do you get enough cooling in the cab after a bit of time running, but the passenger gets no air from the center if you only hook up the right hand hose, which is the easier hose to keep hooked. Right had hose only, then, the passenger gets no air from the center. And if that passenger is your wife on a hot day..... then you move toward reversing the mod!
White K20
Old 01-09-2017, 01:49 PM   #15
Andy4639
Old member
Andy4639's Avatar
I've had this mod for several years at least 10 and have never had any problems with it. My wife rides with me a lot and has never complained about being hot. Temp wise anyway!
Old 01-09-2017, 01:59 PM   #16
jeffahart
jeffahart's Avatar
If you do this mod, then this is the result you can expect. Maybe there is some other variation that I have not seen. But this is the effect of plugging one hole.
White K20
Old 01-09-2017, 02:17 PM   #17
cleszkie
cleszkie's Avatar
I run Vintage Air with my stock center vent with the single hose set-up with the driver side inlet plugged. As mentioned, all flow is directed to the driver. However, I seem to recall that someone was making modified plastic ducting for the center vent with a single hose inlet to fix this issue. I think it might even be Vintage Air.
After some research, I found that it was Brother Truck that has them.
https://www.brotherstrucks.com/67-72...tinfo/CVUG072/
Its still a side inlet, but it looks like the plenum is contoured with a 90 degree bend to push the air straight out the vent.
cleszkie is offline   Reply With Quote
Old 01-12-2017, 10:24 PM   #18
Raleighswb
This is what I am going to use,came from restomod air. My inside unit(also restomod air)has 2 outlets for center vent but I will be blocking one off.
Raleighswb is offline   Reply With Quote
Old 08-28-2024, 03:59 PM   #19
Coursey
Coursey's Avatar
How did this work for you?
I also see brother has this one https://www.holley.com/products/ac_a.../parts/CVUG072
does it help?
On my vintage air kit. You block off one side of the inlet (driver side). But on mine all the air is directed to the passenger side.
Coursey is offline   Reply With Quote
Old 08-28-2024, 10:43 PM   #20
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Onboard with this. RH hose a big PITA, and a mess with the wiring. So I got plugs from LMC for the original parts. Ensured they were sealed tight and right (won't out of the box, easy fix). Clean, and the AC is wonderful.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-29-2024, 12:14 AM   #21
Richard
This piece here https://classicparts.com/chevy-gmc/t...or-center-vent will control the air flow a bit better than plugging off one side of stock ducting manifold. It also provides even more room in that area.
Richard
Old 08-30-2024, 01:11 PM   #22
MikeB
MikeB's Avatar
Sounds like my 1998 model Vintage Air system. The blower pushes the air left out of the airbox in such a way that it can't make the turn completely before hitting the center vent. Also, the airflow out of the passenger side vent is not as strong as the driver's side. Everything is severely left-side biased. Just a poor design, IMO.
I think their latest version may be better, but wish I would have gone with Old Air, and I still may do that someday. IMO, they have a much better designed airbox, even though it hangs down lower.
But 26 years after installation, the V/A system just keeps working, even in 100 degrees temps. All I've ever had to do was replace one hose, along with the receiver/dryer because the system was opened.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
