Old 10-13-2003, 09:50 PM   #1
solidaxel
solidaxel's Avatar
Z Z --3 Question
Does anybody have any miles on a ZZ-3 engine. I am trying to buy a used engine and I want to know if there are any Pros or cons about this engine
Casting number on block 10243880
stamped number on water pump flange 10227ZZ3
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-14-2003, 12:39 PM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I've got a zz4 and love it. The zz3 is a smaller size cam and heads but still a great engine. How many miles on it? If you can do it I would have it cleaned up and install a new cam to liven it up a bit.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 10-14-2003, 12:50 PM   #3
solidaxel
solidaxel's Avatar
Miles, don't know much about it. From the looks of the carbon in the exhaust port it looks like very few miles.
What cam or grind should I use and do the roller lifters need to be changed like on a flat tappet when you install a new or different cam ??
LS 3 4L70E
Old 10-14-2003, 01:19 PM   #4
79BIG10
79BIG10's Avatar
Rollers don't have to be changed if they look good. Look at GM's fast burn cam. This cam is sweet!! I want this cam for mine. It has a real lopey sound and you can get them at most dealerships.
Old 10-14-2003, 04:09 PM   #5
solidaxel
solidaxel's Avatar
What I am hearing you say is that you would change the ZZ 4 cam and go with the Fast burn grind.
This 55 is going to have Air Conditioning and be driven on the streets in very HOT weather. Is the fast burn cam capable of those requirements!!!
LS 3 4L70E
Old 10-14-2003, 04:14 PM   #6
79BIG10
79BIG10's Avatar
Maybe not that much. I would stick with a mild roller cam then like one from Comp or Crane. Try contacting their tech departments and see what they say. You probably need one that will deliver torque down low to drive your 55 with that heavy metal.
