Heater hose
Need help running my heater hoses to my 350 sb,exact location,they are currently plugged any pics would help thank you.
Moderator
![]() ![]() Join Date: Aug 2011
Re: Heater hose
I believe hot coolant is supposed to flow out of the intake manifold, through the 5/8" hose, and into the heater core. The outlet/return of the heater (3/4" hose) is hooked to that fitting on the water pump.
Re: Heater hose
Correct you want the hotter coolant coming from the intake manifold to flow through the 5/8 hose to the core, then return to the water pump through the 3/4 hose. I've seen this in reverse and the heater will have problems.
1966 C10 Short Fleetside 1988 Sportster, 2008 Street Glide Ken's 1966 C10 build "Red Ale" Follow on Instgram: @cv_performance https://instagram.com/cv_performance Harley Performance Parts: CV Performance (Harley related) Enjoying the ride! |
Re: Heater hose
Great info,thank you fellas
Re: Heater hose
Oh by the way does anyone know the lengths of the hose
Re: Heater hose
I'll try to measure mine tomorrow.
Re: Heater hose
Kenfuzed i would apreciate that berry much
Re: Heater hose
Sorry forgot to post the measurement previously. Mine are 36" long. You could probably get away with them slightly shorter.
Re: Heater hose
Thx ken,
