01-08-2017, 06:35 PM | #1 |
Water temp sensor
Hello,
I'm about to install my water temp sensor on my rebuilt 350. Do I use teflon tape and then install it on the motor? Or do I just install it without teflon tape? Thanks, Ramiro |
01-08-2017, 07:27 PM | #2 |
Re: Water temp sensor
Sensor has pipe thread and pipe threads require some type of sealant,pipe dope or teflon tape. Don't over tighten and your good to go. Duck 37
01-08-2017, 07:43 PM | #3 |
01-08-2017, 10:50 PM | #4 |
I just did a couple of temperature sensors, and used Permatex High Temperature Thread Sealant (small tube is item 59214). I used it because I had it around from some NPT fuel fittings.
Everything I've used it on so far has sealed the first time, and a little goes along way. I would'nt hesitate to use teflon tape on the water fittings but figured I'd mention something else.
1969 C10 SWB Stepside, 350, TH350, FiTech Go Street Fuel Injection Last edited by blf; 01-08-2017 at 10:52 PM. Reason: typo |
01-09-2017, 12:00 AM | #5 | |
