01-09-2017, 12:34 AM | #1 |
marvel mystery oil
Anyone use it? In oil or gas, or both? And not just in the ole trucks, newer vehicles also.
Tom
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
01-09-2017, 01:14 AM | #2 |
All about them K’s
Re: marvel mystery oil
I use it quite regularly in our pumping unit and compressor engines at work. It's good for breaking carbon and freeing up sticky rings. I've only used it in oil and thru the intake tho.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
01-09-2017, 01:22 AM | #3 |
smells GOOD!!!
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
01-09-2017, 01:35 AM | #4 |
They say 4 ozs per 10 gals of gas is good for cleaning out the fuel system too
01-09-2017, 01:39 AM | #5 |
Used it once (in the tank of my '13 Cruze so I didn't expect much noticeable difference - just a changeup from Seafoam every 10K) but have researched a little and the consensus seems to be that it works, but is more gentle than Seafoam. I've used Seafoam in intake, fuel, and oil, and am pleased with the results.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
01-09-2017, 02:08 AM | #6 | |
Forty years ago I used to flush my crankcase with Marvel Mysyery Oil after an oil change, and let it drain overnight before refilling with 30 weight. Not so sure that's necessary anymore.
01-09-2017, 02:30 AM | #7 |
makes great gun oil...
01-09-2017, 06:44 AM | #8 |
Been putting it in my mower/snowblower gas. Helps keep the ethonal issues down.
01-09-2017, 10:58 AM | #9 |
also a real good air tool lube....always used it to"fog" engines you were storing....
1970 short step c10 leaf spring 454 |
01-09-2017, 11:08 AM | #10 |
works great on sticky rings
01-09-2017, 11:43 AM | #11 |
I own a bunch of Subarus. They tend to have sticky hydraulic lash adjusters after a while. I've never found anything that works as well as MMO to free them up.
My wife's 2008 Hylander Hybrid is starting to make valvetrain noise. I just bought some MMO for its crankcase. I've never used it in the fuel system, but I think it's the best chemical tool I've used in a crankcase. Last edited by truckster; 01-09-2017 at 11:54 AM. |
01-09-2017, 11:51 AM | #12 |
So what's the best way to use it?
Do you guys add some to the fuel?...if so how much or?.... or pour a little in the carb/intake while the vehicle is running or? I picked up some last year but I haven't put it to good use yet. all Good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
01-09-2017, 12:12 PM | #13 |
I have used in both in the oil and gas. No adverse effects, seems to work, yet no miracle cure for other problems that only mechanical work would resolve.
01-09-2017, 12:36 PM | #14 |
im going to use some in the fuel and oil, im wondering about the intake question also.
01-09-2017, 01:51 PM | #15 |
Put it in my MerCruiser inboard outboard. Was running like crap. Carburetor issues. Put half a bottle in the gas. Ran it for most of the day. Ran like a top after that. Mixed in 20 gallon tank.
01-09-2017, 02:27 PM | #16 |
Custom Sport W/T
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Stuck rings or valves pour MMO in carb until you kill the engine with MMO and let it set for at least a day before starting it. Be sure to call the non emergency number for the fire department and let them know that they can expect calls. You will not have any mosquitos for a while either.
01-09-2017, 02:43 PM | #17 | |
All about them K’s
01-09-2017, 02:54 PM | #18 |
Can it go in the intake through a vacuum line also?
01-09-2017, 03:10 PM | #19 |
01-09-2017, 10:01 PM | #20 |
Ok cool
