Stuck shackle bolt help!
68 c30 how do I remove the rear, greasable, shackle bolts?
![]() I've let it soak in pb blaster, used a torch, and a bfh. Won't budge. |
Re: Stuck shackle bolt help!
Thin cutting wheel on a mini-grinder between hanger and shackle. It's tight and I have ended up cutting into the hanger a bit, then welded up. I have tried a sawzall with the best blades out there and let me tell you, don't even bother. Those are some hardass bolts!
Also, if you have a cutting torch setup you can heat the heck out of it and try turning the end of the shackle bolt thats sticking out with a pipe wrench..
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
![]() Join Date: Oct 2011
...built tough to last, 45 years+ on....lol.
Not necessarily good news today tho' unfortunately Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
Originally to take it out was that one Allen pin and bump it out? Might just have to cut it out and use grade 10 bolts
#6 | |
Who Changed This?
![]() Join Date: Jan 2013
Can you provide a reliable link to the description of Grade 10 bolts?
#8 | |
I have only heard of grade 2,5 and 8 bolts unless you are talking aircraft grade or something like that, grade 8 is all you need.....do you know how to tell the different grades?
