Old 01-09-2017, 10:03 AM   #1
1972RedNeck
1972RedNeck's Avatar
1967 - 1969 4X4 V6 Crossmember
I recently picked up a couple of 478 V6 GMC engines. One of them is likely going into my old F20 Farmall tractor that I just picked up with a bad engine. The other will hopefully find it's way into my '72 K20.
My question for you folks is this. On the 4X4's, is the entire V6 crossmember different from the V8 crossmember or is it just the perches? Does anyone happen to have pictures? Know where to get one?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 01-09-2017, 10:18 AM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: 1967 - 1969 4X4 V6 Crossmember
Subd! don't have an answer for you but I'd like to see this come together. It should be pretty cool.
Tyler
57taskforce is offline   Reply With Quote
Old 01-10-2017, 09:57 AM   #3
1972RedNeck
Bump?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 01-10-2017, 10:22 AM   #4
James the III
The 477.7-cubic-inch (7,828 cc) 478 was one of the largest V6 engines ever built. Gross output was 254 hp (189 kW) at 3700 rpm and 442 lb·ft (599 N·m) at 1400 rpm. Bore was 5.125 in (130.2 mm) and stroke was 3.86 in (98 mm). It was introduced in 1962 as a Magnum engine in the 6500 series trucks.
I'm thinking the frame in these 6500 series is much different than a c-10/20
James the III is offline   Reply With Quote
Old 01-10-2017, 12:32 PM   #5
Classic v6 GMC's
Classic v6 GMC's's Avatar
Here is a pic of the V6 crossmember and perches.
V8 crossmembers and perches are different.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 01-10-2017, 03:40 PM   #6
1972RedNeck
That's out of a 4X4? It definitely is way different from a V8. I suppose the one you have pictured isn't for sale?
Do you know if the transmission was mounted in the same location behind a V6 as a V8 or was it all slid forward?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 01-10-2017, 03:42 PM   #7
1972RedNeck
Sure is. But 305's and 351's were available in GMC pickups up to '69. A 478 should bolt in place of a 305/351.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 01-10-2017, 03:52 PM   #8
James the III
Maybe, but I'm thinking taller deck might be an issue.. and the 478 oil pan might not have the profile to clear the crossmember,
that's a lot of cubes in a 60* 6 hole .
bet a tall deck bbc is shorter.
Old 01-10-2017, 05:29 PM   #9
Classic v6 GMC's
Yes it was out of a 4x4. I actually sold this one to a board member about a month ago.
All the transmissions were mounted in the same location to my knowledge.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 01-10-2017, 08:17 PM   #10
RANDY COX
RANDY COX's Avatar
This is for a 4x4 but for a 292 inline six, very very very hard to find...I searched for over a yr for the passenger side perch, never did find one...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 01-10-2017, 09:50 PM   #11
Classic v6 GMC's
The crossmember is the same for 292 and V6. The perches are v6 only.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 01-11-2017, 12:12 AM   #12
MusicMan70
MusicMan70's Avatar
Here is a link to a Board members album; I think he goes by ERL. His truck is Majestic! He may have some answers or specifics as well.
http://www.jackpalmerphotos.com/CarD...C-V6/i-nP3rJcR
Here are some photos I saved from an old EBay listing of a 1969 V6 4WD.
*on a side note, the engine mount on the driver-side, does not appear to be the block style I have normally seen for these engines.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 01-11-2017, 11:38 AM   #13
1972RedNeck
305 and 478 have the same deck height. 305 pickup oil pan will fit on a 478.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 01-11-2017, 11:39 AM   #14
1972RedNeck
Good to know. Did you sell the cross member and perches or just the cross member?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 01-11-2017, 11:43 AM   #15
Classic v6 GMC's
The cross member and perches.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
